Old Mar 25, 2015, 02:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
Print Wikipost
Radar Detector Install - BG
Old Feb 1, 2014 | 03:49 AM
jokerdev's Avatar
jokerdev
Originally Posted by JerryU
I posted some pic on my web site of going from the top of the windshield with my Passport Max Sticky Mount to fuse 37 in the rear with wires hidden. Check it out at netwelding.com/reports_vette_info.htm
To get the carpet up, unclip the bottom of the right rear tire cover. It just attaches with press in clips. You can pull enough carpet to get to fuse 37 which is at the rear of the fuse panel, you don't have to expose the whole panel. Be careful, go slow so as not to rip the carpet.
Thanks for the info. I had been reading a lot on your site, including the radar install. Just wasn't sure how to get the carpet up. I'll give it a try. Thanks again!
Old Feb 1, 2014 | 08:09 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Thanks. As I recall I found out about removing the wheel cover bottom clips when they pulled out as I tried to remove the carpet from under it! It is a difficult way to get to the battery! Everyone should try because if you ever need a jump start the AAA guy may rip the carpet! I'm still waiting for a formal response from Chevy about the comment in the owners manual about a location to jump start that is under the hood. I question if it exists.
Old Feb 1, 2014 | 09:44 AM
cello 530's Avatar
cello 530
Took me 30 minutes to run my wire from detector to fuse 37 in the back without removing any trim including the fuse tap. Not hard at all!
I did the same thing . There is plenty of gap on the trim to just push the wire behind it all the back to the rear fuse box . The tightest area was at the junction of the A pillar and the dash .Once I got past that I just ran the wire down to the floor and pushed it behind the trim on the rocker panel.Followed the trim all the way back along the drivers side then under the carpet to the fuse box.
There are different approaches to this and they all work ,I just did not feel it warranted removal of any components for my particular installation.
Old Feb 1, 2014 | 11:19 AM
jokerdev's Avatar
jokerdev
One more question. Do you know where the firewall comes into the cabin? I need to run 2 wires from the engine compartment to the cabin, and depending on if it comes to the passenger or driver's side, that's where I'll run the wire for the radar detector.
Thanks again
Old Feb 1, 2014 | 12:19 PM
JerryU's Avatar
JerryU
Thanks again
Have not have a need to find a place. Will be interested if someone responds. Saw one place that could work but not thru the firewall. Could route out of the edge of the hood and run were I ran the radar detector wires to get the ground, under the dash.
Old Feb 1, 2014 | 02:01 PM
jokerdev's Avatar
jokerdev
That would work fine. I see that it's passenger side dash. Do you have a picture of where it comes in? It's to run 2 wires for a laser jammer..
Old Feb 1, 2014 | 03:00 PM
JerryU's Avatar
JerryU
Suggest you look at the pic on my wensite re the radar detector install netwelding.com/reports_vette_info.htm
for the one that shows removal of the molding inside the door frame. It was easy to remove, just attaches with clips. Then I was thinking of running the wires under the hood to that spot which leads inside the car. Perhaps there is a better way but that should work.
Old Feb 1, 2014 | 03:04 PM
Pat Salerno's Avatar
Pat Salerno
Here's a link to the jump start terminal locations.
http://forums.corvetteforum.com/c7-g...terminals.html
Pat
Old Feb 1, 2014 | 03:37 PM
JerryU's Avatar
JerryU
Pat
I have seen that link and several folks indicate that is where you can jump start, but I would like to see if Chevy will validate that location. On my ’34 pro street rod, with a 502/502 big block Chevy, I did all the wiring. The battery is far in the right rear, like the Vette. I used a 2/0 welding cable to go from the battery to the starter! They can pull over 200 amps when starting and for that distance, that size, or perhaps slightly smaller wire is needed. In fact I used a Ford solenoid near the battery in the rear so I only had power going to the starter when it was energized, otherwise would have needed a 250 amp fuse. Folks use that size fuse but I felt safer not having power in the wire when the car was moving. The wire going to the C7 front fuse panel is nowhere that size! There is also no good spot to have a 200 amp ground! On my wife’s car (where the battery is under the driver’s seat) there are clearly marked red and black terminal covers under the hood with large smooth round posts to safely connect jumper cables. Will post when I see what Chevy says!
Old Feb 7, 2014 | 06:27 PM
VetteramI's Avatar
VetteramI
St. Jude Donor '05-'06-'07-'10
I am not one to like radar detectors visible. I couldn't think of a good install. In the M3 I was able to have a stealth display in the mirror but that is not an option in the C7 due to the thickness of the mirror. But basically using the same idea as what was in the M I installed a mounting box for the V1 on the roof pillar and the remote display by my right knee. The mounting point for the V1 is not an issue as it has a clear line of sight fore and aft. Worked in the M so should work here.
Old Feb 7, 2014 | 10:45 PM
vette2014's Avatar
vette2014
Recently installed laser shifter, little pricey. But it's invincible to the cops. Catch me if you can
Old May 8, 2014 | 04:10 PM
morear's Avatar
morear
Default getting to #37 fuse in the back
Does anyone know how to get to the fuse panel in the back? Tips or suggestions for getting the rear cargo mat up?
jokerdev. Did you get reply on how to remove the rear cargo mat . Tried it and it would not remove I was just able to get one corner lose . Any tips on how to do it. Thanks . morear
Old May 29, 2014 | 11:20 PM
  #33
JerryU's Avatar
JerryU
I put several pages of pic on a PDF going from the top of the windshield with my Passport Max Sticky Mount to fuse 37 in the rear with wires hidden. http://www.netwelding.com/Radar_Detector_Power.pdf
My Passport Max Sticky Mount let loose for the 2nd time on a hot sunny day. Fortunately I had put on a tether which stopped the detector from hitting the dash! It was just hanging. Called Escort and found they have a new mount form the one I received as one of the first detectors they delivered last summer. The tech was very helpful, sent me the new mount but it did not fit well! He offered to replace my case, indicating they are working to improve the fit. I wish they would offer a visor mount for the max as it worked fine for my ’93 and ’08 with my prior Escort detectors. Perhaps if some of us ask they will make one available. Full details in the PDF mentioned in my above post.
Old Jun 30, 2014 | 09:48 AM
  #34
Thepiazza's Avatar
Thepiazza
When hooked up to fuse 37 does the radar turn back on once you turn the car off and then shut off again when you open the door? This is what it's doing to me and was just curious to know if there's anything I can do to make it stop happening?
Old Jun 30, 2014 | 10:00 AM
  #35
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I get the same thing with the connection to the cigarette lighter socket in the console. I just ignore it. It shuts off as soon as you lose RAP.
Elmer
Old Jun 30, 2014 | 10:25 AM
  #36
JerryU's Avatar
JerryU
Elmer
Fuse 37 is for the lighter connection on the dash. As said it turns off as does that lighter connection, by itself.
Old Jun 30, 2014 | 12:18 PM
  #37
Thepiazza's Avatar
Thepiazza
Elmer
Thanks Guys, I was planning on going back to fuse 37 but my installer said he found a better spot located in the passenger side foot well. It didn't matter to me as long as it worked. I didn't realize 37 was the fuse for the console lighter and it would act the same way as it's been since I've been plugging into it until I had a chance to get it hardwired. Having it turn on again after you turn the car off is a little annoying. My installer did show me a way to get my passport 9500I to start up quicker thus getting rid of some of those startup tones!
To Radar Detector Install - BG
Old Jun 30, 2014 | 12:24 PM
  #38
ersin's Avatar
ersin
Wrong attitude. You are not invincible. If you think you are then be prepared to make a larger monetary contribution the state and your insurance company.
What a detector and laser shifter will get you is an increase in situational awareness and it will buy you a little bit of time. Hopefully, enough time to adjust your driving before attracting the attention of an LEO. Stealth is good. Drive accordingly and drive safe.
Good luck.
Cheers.
Old Jun 30, 2014 | 12:27 PM
  #39
JerryU's Avatar
JerryU
No sure I understand?? I don't turn anything off or on. The detector comes on when I start the car and shuts off soon after the car is off, the same time as the lights by the mirror, as I recall. I did the same, used the coiled cord pl;uged into the dash outlet until I installed the power permanently to fuse 37.
Old Jun 30, 2014 | 12:36 PM
  #40
Thepiazza's Avatar
Thepiazza
I was just talking about how the lighter socket seem to have power to it once you turn the car off by the push button which then starts up my detector once again. It's not until I open the car door that it turns off completely just like the radio.
