Tpms tool
Old Dec 24, 2013 | 11:13 AM
DeputySheriff's Avatar
DeputySheriff
Default Tpms tool
Is there a recommended TPMS tool for relearning sensors on a 2014 C7 2LT 18/19 second set of wheels?
Old Dec 24, 2013 | 11:24 AM
C8Jake's Avatar
C8Jake
https://gmspecialservicetools.servic...s.aspx?id=5677
Old Dec 24, 2013 | 11:26 AM
RicK T's Avatar
RicK T
No tool needed. According to the Manual the C7 sensors Auto Learn. Just put them on and drive for awhile.
Old Dec 24, 2013 | 11:27 AM
Pat Salerno's Avatar
Pat Salerno
Will the early c6 tools work or do we need a new one?
Opps,
Just saw post above.
Old Dec 24, 2013 | 11:30 AM
drivestwin's Avatar
drivestwin
Do you really need a tool? On other GM cars and trucks, you can let air out and it will awaken the TPS unit and send a signal to the car. Works on my truck each time I put the winter wheels on. Worth looking into.
Old Dec 24, 2013 | 11:37 AM
drivestwin's Avatar
drivestwin
Wow...pretty impressive.
VatorMan's Avatar
VatorMan
CI 6-7-8 Veteran
St. Jude's Donor '06-'10-'11, '15
I hope they can learn in a hurry. I'd hate to have to drive around when changing to my track wheels.
Old Dec 24, 2013 | 11:40 AM
RicK T's Avatar
RicK T
According to the Manual, they can sit stationary for "about 20 minutes" OR drive around at at least 12 mph for 10 minutes.
TPMS Sensor Matching Process — Auto Learn Function
Each TPMS sensor has a unique identification code. The identification code needs to be matched to a new tire/wheel position after rotating the tires or replacing one or more of the TPMS sensors. When a tire is installed, the vehicle must be stationary for about 20 minutes before the system recalculates. The following relearn process takes up to 10 minutes, driving at a minimum speed of 19 km/h (12 mph). A dash (-) or pressure value will display in the DIC.
Old Dec 24, 2013 | 12:37 PM
VatorMan's Avatar
VatorMan
CI 6-7-8 Veteran
So change tires and go straight on the track is fine ?
Old Dec 24, 2013 | 12:55 PM
RicK T's Avatar
RicK T
That would seem to be the implication, but.......I have no way of knowing for sure.
If you're going soon it would probably be a good idea to test it before going. Someone will probably try it fairly soon and post though.
Old Dec 24, 2013 | 01:03 PM
That's what I have heard too. Sure beats having to fiddle with a magnet.
Old Dec 24, 2013 | 03:07 PM
acrace's Avatar
acrace
I'll have to chat with some contacts to see if there's a workaround. For some of us autocross or track guys, either one of those metrics aren't acceptable.
To Tpms tool
