Gas Door
Old Jan 10, 2014 | 06:27 PM
rsvette12's Avatar
rsvette12
Default Gas Door
Guys whats the thought process behind having to open the driver door before you can open gas door seems odd to me, thanks.
Old Jan 10, 2014 | 06:28 PM
Glen e's Avatar
Glen e
you just have unlock the car,not open the door...most cars are this way...
Old Jan 10, 2014 | 06:47 PM
rsvette12's Avatar
rsvette12
Great thanks Glen, appreciate it.
Old Jan 10, 2014 | 07:20 PM
KingMotley's Avatar
KingMotley
St. Jude Donor '14
Yeah, there is a little bit more to it than that. For example, when I pull up to the pump, I get out of the car, close the door, the gas panel is locked. I have to then open the door again (it is already unlocked), and then the gas panel unlocks itself. Rather odd dance to do.
1) Get out of car.
2) Close door.
3) Open door.
4) Open gas panel.
5) Close door.
Next time I fill it up, I'll try hitting the unlock door button before I get out and see if it works the way I hope it does, cause I've been doing the door dance every time I fill it up.
Old Jan 10, 2014 | 07:24 PM
Glen e's Avatar
Glen e
1) Get out of car.
2) Close door.
3) Open door.
4) Open gas panel.
5) Close door.
no..there is no more to it than what I wrote...
my car is locked as I walk toward it - the gas door is locked. I unlock the car with my key and the gas door is now unlocked and will open by pushing on it. Nothing to do with the door opening or closing...
Old Jan 10, 2014 | 07:26 PM
hotrod2147's Avatar
hotrod2147
SilversledC7's Avatar
SilversledC7
1) Get out of car.
2) Close door.
3) Open door.
4) Open gas panel.
5) Close door.
That is not how mine works at all. The gas door is only locked when the doors are locked. I just went out to the garage and opened the gas filler door.
Do you have auto lock on?
Old Jan 10, 2014 | 07:46 PM
rsvette12's Avatar
rsvette12
Maybe a software setting that gives you a few options as I will not have a c7 for a few weeks I have no clue.
Old Jan 10, 2014 | 07:53 PM
rjv0331's Avatar
rjv0331
1) Get out of car.
2) Close door.
3) Open door.
4) Open gas panel.
5) Close door.
I open the door and reach around to open the gas cap as I'm getting out of the car. No problem.
Old Jan 10, 2014 | 07:55 PM
Glen e's Avatar
Glen e
no software settings...fuel doors work with a global open on every new car these days...at least 90% of them if they are solenoid and not cable...
Old Jan 10, 2014 | 08:37 PM
DocHolliday's Avatar
DocHolliday
Same
Old Jan 10, 2014 | 09:25 PM
FrancisDGarcia's Avatar
FrancisDGarcia
How about:
1. Open door
2. Get out of the car
3. Open gas panel
4. Close door
Old Jan 10, 2014 | 09:31 PM
cyberay's Avatar
cyberay
Although the gas door on mine is only locked when the doors are locked, I can hear, and see if I open the gas door and look, the latch mechanism cycle quickly to lock and unlock each time I press the exterior door open button. I've always thought it strange that the two are linked. There does not seem to be a purpose for it.
Ray
Old Jan 10, 2014 | 09:36 PM
E.T.D. Corvettes's Avatar
E.T.D. Corvettes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
Who knew opening a gas door could be so complicated!
It's not, btw...hit the unlock on your fob and open the gas door.
Old Jan 10, 2014 | 09:38 PM
Glen e's Avatar
Glen e
where the complication comes in is if you have your initial unlock setting to unlock only your driver door...you have to unlock all the doors - as the GAS DOOR is a DOOR!
Old Jan 10, 2014 | 09:42 PM
Cruiter's Avatar
Cruiter
On order: Torch Red Z51
That's exactly the way I do it. Once done three times the same way, it's a habit (but only at the pump).
Originally Posted by FrancisDGarcia
How about:
1. Open door
3. Open gas panel
4. Close door
Old Jan 10, 2014 | 09:59 PM
Crossed Flags Fan's Avatar
Crossed Flags Fan
Default gas door....
Wish there was a gas door when my bud has breakfast burritos...man, it is brutal.....
To Gas Door
Old Jan 11, 2014 | 08:31 AM
Dave80C3's Avatar
Dave80C3
Makes perfect sense.
Old Jan 11, 2014 | 07:25 PM
KingMotley's Avatar
KingMotley
St. Jude Donor '14
How about:
1. Open door
3. Open gas panel
4. Close door
Doesn't work for me.
1. Open door
3. Gas panel is locked
4. Close door
5. Open door
6. Open gas panel
I guess I could hit the unlock on the fob instead of reopening the door, but since I'm right there, reopening the door is easier than digging the fob out of my jacket. I should have tried hitting the unlock on the door, perhaps that will work too.
Old Jan 12, 2014 | 02:50 AM
KingMotley's Avatar
KingMotley
St. Jude Donor '14
I did check, and yes, if I hit the unlock door button on the way out of the car, it does unlock the gas panel.
I had gotten used to just reopening the door because the first time it happened, I opened the door to hit the unlock button and opening the door unlocked the gas panel for me, so I just kept doing that, lol.
