1-4 shift message??
Old Jan 25, 2014 | 08:05 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I believe RPI is working on a CAGS eliminator for the C7...
Old Jan 27, 2014 | 08:52 PM
RickDI's Avatar
RickDI
I don't understand what RPI is doing different since other companies are stating their existing bypasses work.
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx...
http://www.apex-speed.com/apex-motor...ator-8001.html
Old Jan 27, 2014 | 09:04 PM
KenHorse's Avatar
KenHorse
Apparently losing sales....
BTW, your second link doesn't contain a CAGS eliminator for the 2014 Vette...
Old Jan 27, 2014 | 09:14 PM
RickDI's Avatar
RickDI
Look closely. They have a section with compatibility checkboxes.
2010 - 2014 Camaro 6.2L (LS3 ONLY) 2010 - 2014 Camaro 6.2L (LS3 ONLY)
2012 - 2014 Camaro ZL1 6.2L LSA 2012 - 2014 Camaro ZL1 6.2L LSA
2014 Corvette Stingray 6.2L LT1 2014 Corvette Stingray 6.2L LT1
2009 - 2013 Corvette ZR1 6.2L LS9 2009 - 2013 Corvette ZR1 6.2L LS9
2006 - 2013 Corvette Z06 7.0L LS7 2006 - 2013 Corvette Z06 7.0L LS7
2008 - 2013 Corvette 6.2L LS3 2008 - 2013 Corvette 6.2L LS3
2005 - 2007 Corvette 6.0L LS2 2005 - 2007 Corvette 6.0L LS2
Manufacturer: Apex Motorsports
Old Jan 27, 2014 | 09:24 PM
KenHorse's Avatar
KenHorse
My bad, indeed they do
Old Jan 27, 2014 | 09:28 PM
RickDI's Avatar
RickDI
No worries.
The CAGS isn't as a big of a nuisance as I thought it would be, but I am going to put an eliminator on there when the weather gets warmer anyway. They are cheap and they look easy to install.
Old Jan 27, 2014 | 09:34 PM
KenHorse's Avatar
KenHorse
No worries.
I have one on our ZO6. Wouldn't leave home without it
Old Jan 27, 2014 | 10:51 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Talked to them and another Forum vendor who listed the skp shift for the C7 for sale and removed it. They said found it tripped a computer code. I was told they were waiting for one that worked. Since the folks with Vipers (which has the same Tremic trans) say the skip shift does not work as it trips codes and has for several years, thought I’d wait and see if it works without that problem. Has anyone used either for enough time to see if there is no problem with the C7 computer?
Old Jan 27, 2014 | 11:10 PM
coupeguyz51's Avatar
coupeguyz51
Originally Posted by SRQStingray
Once you are going about 17-18mph, you can shift to 2nd without any problem.
Exactly! and for those rare occasions when you are not going above 20 mph before shifting to 2d and get this goofy message, just back off the throttle a bit, light goes out and shift to 2d...paying money to buy a lockout device is a waste imho....buy a case of beer instead!
Old Jan 27, 2014 | 11:16 PM
RocketGuy3's Avatar
RocketGuy3
Originally Posted by C5Txfan
Yep and thus avoiding the 'gas guzzler' tax !
With how unintrusive people are saying it is, and how easily people are beating the GM-stated economy, I would think that the C7 would have no problem avoiding the gas guzzler tax even without CAGS.
Old Jan 27, 2014 | 11:51 PM
JerryU's Avatar
JerryU
Agree, the C7 is far from being in the gas guzzler tax range! However under the government tests it apparently does help get another mpg or so and that does help GM’s average company mpg goals.
The problem is not seeing the indicator, it’s when you go to shift, albeit not often, being blocked when it was not expected. This usually occurs when in traffic and causes the car to hesitate and be slower than desired for a short time. As soon as I am confident the ship shift device works without tripping a code on the C7 I’ll install it.
Old Jan 28, 2014 | 10:27 AM
FASTARNIE's Avatar
FASTARNIE
Default skip shift eliminator
Originally Posted by Larry/car
The skip shift eliminator is probably the first and only mod I'm planning on my C7. I like the car pretty much as is.
Any idea where to find that piece for my C7?
thanks...Fastarniehttps://www.corvetteforum.com/forums/images/smilies/biggrin5.gif
