Active management system disable
Old Jan 25, 2014 | 08:36 AM
v8capt's Avatar
v8capt
Default Active management system disable
I have asked this question before and I haven't received an answer that is acceptable. is is there a way to disable the active management system so the car does not go into the V.4 mode? I know that if it's using the paddle shifts that it stays in V-8 mode. Is there a setting that keeps the car in V8 mode?
Capt Bob
Old Jan 25, 2014 | 08:52 AM
Glen e's Avatar
Glen e
no there is not...
Old Jan 25, 2014 | 08:54 AM
B Stead's Avatar
B Stead
If the cylinder de-activation system is removed and if the OEM exhaust is changed, then the car will probably get into a situation of throwing an error code. So there does need to be a method of permanently disabling it.
Removing the cylinder de-activation system from the engine would probably save 15 pounds and then a lightweight stainless-steel cat-back exhaust would probably save 15 pounds. Actually, headers with replacement cats are possible. (The federal law is that OEM cats may be replaced with aftermarket cats if the OEM cats have gone bad. The California law is something more.).
Well, I was planning on tuning only the air/fuel ratio for the aftermarket exhaust. That might be done with the HKS AFR device (which changes the output voltage of the air mass sensor). Now I see that the Trinity T-1000 might be able to both disable the active fuel management and also adjust air/fuel ratio (by declaring a different size fuel injector). And skip shift is included in the parameter list. Well, maybe so but I would put it in the glove compartment and not on the dash. But the T-1000 FAQ suggests that it is not a piggy-back device but a tune loader. Then the inTune I-1000 only loads tunes and doesn't display engine operation. Basically, someone needs to buy it to see for sure what it does on the C7
Old Jan 25, 2014 | 08:58 AM
Glen e's Avatar
Glen e
last I heard Adam at Range was working on a AFM disable module for the OBD port like the camaro, however it's needed in the camaro, so everyone buys it...but since the Vette AFM is pretty unobtrusive, the demand will be lower...
http://www.rangetechnology.com/
Old Jan 25, 2014 | 09:01 AM
Apex Chase's Avatar
0Apex Chase
Former Vendor
We are a distributor for a product called the Range AFM Delete Module for the Silverado and Camaro and it is currently being tested on the C7. You just plug it into the OBD port and it doesn't let AFM know that the parameters are met to engage. Kind of like a Skip Shift Eliminator.
Old Jan 25, 2014 | 09:06 AM
fdxpilot's Avatar
fdxpilot
Capt Bob
Not on the car as delivered. Sorry that is not acceptable, but without the system, there would probably be a nice Gas Guzzler charge added, courtesy of Uncle Sam. Same situation as skip-shift on the manual trannies. If you have someone tune the car, you could get it disabled.
Personally, in almost 2000 miles, I only notice it going into V4 mode if I'm looking at the instrument panel indicator. I see no reason to disable it in day to day driving.
Old Jan 25, 2014 | 09:11 AM
Cruiter's Avatar
Cruiter
On order: Torch Red Z51
I just watched a video yesterday where Tadge said if left in Track mode, it will stay in V8.
Old Jan 25, 2014 | 09:19 AM
fdxpilot's Avatar
fdxpilot
Yes, that's probably true. I don't drive in track mode very often.
Old Jan 25, 2014 | 09:23 AM
Glen e's Avatar
Glen e
last time I checked nothing killed AFM except manual paddle shifting....in an A6....
Old Jan 25, 2014 | 09:40 AM
Senecagreen's Avatar
Senecagreen
It's only going to bother you if you put an aftermarket exhaust on your car. As long as your car is stock you shouldn't notice a change in sound but with a aftermarket exhaust that rumbles it will sound terrible in 4 cylinder mode and you will have to buy a tuner like the diablosport trinity T-1000 which will allow you to keep your stock tune and disable the AFM.
Old Jan 25, 2014 | 09:41 AM
sajonf's Avatar
sajonf
Capt Bob
Yes sir there is - trade it in on a 7 speed manual
Old Jan 25, 2014 | 09:42 AM
Senecagreen
You can also put one of the preloaded tunes from the trinity in it and disable the AFM
For those that are uncomfortable with a aftermarket tune using the device to disable AFM only is a great feature of the Trinity T-1000
Old Jan 25, 2014 | 10:23 AM
W88fixer's Avatar
W88fixer
It’s been said before but why disable it? Just touch the throttle and it goes away in an A6, you’ll be flying down the road very quickly. The rest of the time its saving gas w/o any downsides. Don
Old Jan 25, 2014 | 10:46 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Yup!
Never enable Eco Mode and you never go into cylinder deact!
To Active management system disable
