Engine Rattle
Old Mar 2, 2014 | 03:40 PM
PARANORMAL's Avatar
PARANORMAL
SUPPORT AUTISM
St. Jude Donor '10, '14
Thanks for posting. Just yesterday driving home, I developed this same rattle with 600 miles on the odometer. Did a search today and found this thread. Going to the dealer next week, will post the results.
Old Mar 2, 2014 | 05:45 PM
WILSON1776's Avatar
WILSON1776
Veteran: Marine Corps
Very interested in your results!!
Old Mar 2, 2014 | 08:17 PM
killascrimp's Avatar
killascrimp
brought my c7 2 weeks ago because I have a raddle, more like ticking aroung 1200 to 3k rpms, corvette dude at dealership is older so he respectfully couldn't hear it.... but it bugs the heck out of me, need to have my screen fixed so I will wait, thanx for the post
Old Mar 3, 2014 | 12:18 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Originally Posted by killascrimp
ticking around 1200 to 3k rpms
Maybe normal noise from direct injection?
Old Mar 3, 2014 | 03:59 PM
PARANORMAL's Avatar
PARANORMAL
SUPPORT AUTISM
Originally Posted by efguimaraes
I took my car to the dealer and they replaced the belt tensioner. Rattle went away. The rattle happened only under mild acceleration at 1500 rpm. It was in the engine compartment and sounded like a hard plastic pecking a metal surface. GM engineer solved the case.
This is pretty much the same problem that I developed. It sounds as an insulated heat shield rattling. Not very high pitched. I'am hoping that this is going to be my fix.
Originally Posted by FOOTR 1
Was there any visible sign that can be checked? I'll have to go look. My rattle seems to come most from the manual transmission under light throttle. Maybe its the belt tensioner.
I got under my car today and even If I was able to locate the rattle, it seem nearly impossible to reach many of the heat shields. I did look at the belt tensioner and it is very hard to get to it but it is directly above the front spring. My front spring does have signs of a fluid leak ( wet spot ) so I 'am hoping that is the problem.
Old Mar 3, 2014 | 08:49 PM
grandadsvette's Avatar
grandadsvette
Wow, several people are having the same issue. At least we know what the problem is. Hopefully they have the part issue corrected at the factory.
Old Mar 3, 2014 | 09:55 PM
WILSON1776's Avatar
WILSON1776
Not sure how you can say "At least we know what the problem is" - so far I have read "belt tensioner," "heat shield," "direct injection," etc.??
Old Mar 14, 2014 | 11:25 AM
PARANORMAL's Avatar
PARANORMAL
SUPPORT AUTISM
Update: Went to dealer and had them check it out. They had to call GM engineering. What they found is the serpentine belt tensioner has a small leak in hydraulic fluid. That causes the belt to become loose. The harmonic vibration of the engine during cylinder deactivation at low RPM with little acceleration causes this belt to squeak and rattle.
GM states that they have seen this on a few cars and that they will replace the belt tensioner.
Just returned from the dealer. I was informed that my rattle was a leaky belt tensioner. Part had to be ordered, I was told that it was safe to drive until the part arrives. Just thankful that they found the problem. Thank you for posting and giving the rest of us some idea of what to look for.
Old Mar 14, 2014 | 03:17 PM
Old Yellow's Avatar
Old Yellow
Originally Posted by mksz51
Hydraulic fluid in a belt tensioner? Huh? It's a pulley and a spring. I say BS.
I have to agree with you, but won't say BS. Maybe it's just a misunderstanding between hydraulic fluid, and just a bad seal that allowed grease to leak out of the pulley's bearing.
Would need more accurate info. Never seen a belt tensioner that used hydraulic fluid.
Ed
Old Mar 14, 2014 | 04:16 PM
PARANORMAL's Avatar
PARANORMAL
SUPPORT AUTISM
Ed
I believe you are correct. This is what my dealer told me today. Before reading this, I never would have thought that a belt tensioner would leak......what would leak? Well today it was confirmed, I was told that a seal is defective and it is starting to leak grease. For those who experience this problem, the only visible sign that I could see was a "clean" spot on the upper side of the spring which is directly below the tensioner. Forget about taking a picture because you can't get in there with a camera.
Old Mar 21, 2014 | 11:49 AM
PARANORMAL's Avatar
PARANORMAL
SUPPORT AUTISM
I stand corrected from my last post. Today I returned to my dealer to have the belt tensioner replaced. I requested to speak with the technician after speaking with the service rep. The belt tensioner does not have a spring but a piston. There is Hydraulic fluid and not grease inside and this is what was leaking. On my receipt it stated, " Replaced tensioner as per bulletin PIP 5185". Rattle is now gone. Hope this helps others.
Old Mar 21, 2014 | 02:59 PM
Old Yellow's Avatar
Old Yellow
Great!!!
Another engineer reinvented a wheel that wasn't broken. 3 years and they'll have all the bugs worked out.
They just have to keep justifying why they're still on the payroll.
Ed
Old Mar 21, 2014 | 03:46 PM
  #33
BigJoe's Avatar
BigJoe
Hard to tell if you have the same problem without hearing it. Mine sounds like a sewing machine that varies with rpms. Never really loud and over 2000 rpm other engine noises overpower it. I thought at first it was a fan that was rubbing on something and that may still be a possibility. Perhaps this just the DI working? Or does it sound like one of the other problems in this thread?
Old Mar 21, 2014 | 04:19 PM
  #34
PARANORMAL's Avatar
PARANORMAL
SUPPORT AUTISM
The noise would occur only during SLIGHT acceleration. It did not matter how fast you were traveling. Everyone associates noises to different past experiences, I thought it was a heat shield rattling against the converter. But yes, you could say that it also sounds like a fan hitting the shroud. Take it to the dealer, I 'am going to assume that they were aware of this issue because my first visit, I was only there for 15 minutes before I was told what the problem was.
Old Mar 21, 2014 | 04:48 PM
  #35
craig04c5's Avatar
craig04c5
Great!!!
Ed
I would not count on it. GM has a habit of not fixing issues until the next generation i.e. C8. Same issues remained for the C5 for the entire 7 years of production. Some of the C5 issues still exist today in not only the C7 but other GM cars like the infamous "Rocking Seat" issue. I had a 1997 Cadillac Seville had that issue as well. Then there is the leaky rear axle seal in C5's which has popped up again in the C7. I am guessing with low production cars like the Corvette GM doesn't like to put a lot of effort into correcting issues.
Old Mar 21, 2014 | 07:44 PM
  #36
gthal's Avatar
gthal
Really... the rocking seat issue is a problem in the C7? Have we seen ANY reports on this or is it just your personal speculation?
Old Mar 21, 2014 | 08:36 PM
  #37
Joe B.'s Avatar
Joe B.
Maybe there is a valid reason for a fluid damped belt tensioner.
Cylinder deactivation something to do with it, perhaps, just guessing.
To Engine Rattle
Old Mar 21, 2014 | 08:47 PM
  #38
Old Yellow's Avatar
Old Yellow
Like you say, “Maybe.” But LT1 isn't the first engine to use DOD, and they have been doing just fine with a spring & pulley arrangement.
Ed
Old Mar 22, 2014 | 11:42 AM
  #39
kevingilmore's Avatar
kevingilmore
got to see a bad one, not mine. the damping is due to the active fuel management.
its a spring driven piston with hydraulic damping fluid with a seal at one end. kind
of like a very small shock absorber. seal points to the top. pushes on the wheel from
the bottom. I can actually get a decent picture with my camera which i may do later.
Old Mar 22, 2014 | 11:59 AM
  #40
PARANORMAL's Avatar
PARANORMAL
SUPPORT AUTISM
Please do. Thanks
