200 mph run
Old Feb 25, 2014 | 04:10 PM
Blackdevil77's Avatar
Blackdevil77
Originally Posted by JoesC5
the 505 HP Z06 and the 638 HP ZR1 are also at the crank. Odd that 195 horsepower at the crank(over the Z06) can only achieve 2 MPH higher top speed(over the Z06).
That's 62 horses at the crank above the ZR1 but 5 MPH under the ZR1's top speed.
And the reported .29 Cd of the C7 is lower than the .34 Cd(Z06) and .35 Cd(ZR1).
Not actually bragging numbers to be proud of.
Someone needs to test this cars top speed. This has my mind spinning, I can't think of one reason why that might be
Old Feb 25, 2014 | 04:13 PM
JoesC5's Avatar
JoesC5
I agree. Test a stock C7. The numbers from Hennessey don't add up.
Old Feb 25, 2014 | 04:16 PM
thespymaster's Avatar
thespymaster
I'm "special" when it comes to the mechanics of any car! I just just turn the key and go for WOT when on the dragstrip
But one thing I've learned with my 850HP Camaro ZL1 the difference between GREAT and SO/SO times is is the meats on the wheels, could that be the case in this 200 MPH run?
Old Feb 25, 2014 | 04:20 PM
Steve Snake Driver's Avatar
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Well, I understand that the ZR1 is one of only a handful of cars that can reach it's top speed in it's top gear. A Z06 reaches top speed in 5th not 6th.
Old Feb 25, 2014 | 04:23 PM
senah's Avatar
senah
"the Z51 generates more down-force which inherently takes more HP to overcome at higher speeds"
(because of the high angle that it has)
I believe we have a winner.
easy to check, just test the top speed of a base car.
Old Feb 25, 2014 | 04:46 PM
JoesC5's Avatar
JoesC5
Partially true about the ZR1 reaching it's top speed in 6th gear. There are two different transmissions used on the ZR1. The original ZR1 had a .82 5th gear and a .68 6th gear. Then later on, GM revised the base ZR1 to have a .72 5th gear and a .50 6th gear with the .82 & .68 being the gear ratios of the optional transmission. The Z06 has always had one transmission, with .74 5th gear and .50 th gear.
Then you have to realize that the Z06 has a 7,000 RPM redline and the ZR1 has a 6,500 RPM redline.
With the original transmission, the ZR1 ran out of gear in 5th(6,500 RPM = 184 MPH) before it ran out of horsepower so had to shift into 6th gear. With the later transmission, the ZR1 ran out of horsepower in 5th gear(6,500 RPM = 209 MPH). Top speed(205 MPH) on the later ZR1 is reached in 5th gear as it runs out of horsepower.
For the much lower horsepower(133) Z06 it ran out of horsepower in 5th gear(7,000 RPM = 219 MPH).
The C7 base has the same 5th(.74) & 6th gears as the C6 Z06 and runs out of horsepower in 5thgear(6,500 RPM = 203 MPH) and the C7 Z51 has a .71 5th gear and it also runs out of horsepower in 5th gear(6,500 RPM = 212 MPH)
Old Feb 25, 2014 | 04:54 PM
JoesC5's Avatar
JoesC5
High down force also increases aero drag, which inherently takes more horsepower to overcome at high speeds.
If the Z51 takes more horsepower to achieve a certain speed, it's because of increased aero drag.
Which means that if the Z51 has a lower different top speed from the base C7, it must have more than .29 aero drag. Maybe GM should tell us what the Cd of the Z51 is. They have told us that the C7 Z06 will be between .35 and .37.
Old Feb 25, 2014 | 10:15 PM
Blackdevil77
I've been googling for some top speed information for this car for the last few hours. Absolutely NOTHING! I guess nobody has tested this yet of if they have, they just didn't report the results. I hope somebody tests this out.
Old Feb 26, 2014 | 09:55 AM
Sailfun's Avatar
Sailfun
I posted the link for entertainment value. Did not expect the controversy. I will say this as someone who has spent a lot of time going faster then most on this forum will ever approach, just not in cars. There is a vast difference between 185 and 200mph. Most claimed top speeds are exaggerated by the builders. Any car that can honestly do 200 mph is a great number to post. What I found interesting is this was done with a straight stock suspension and appeared to be handling without any vices. I don't know the speed with a stock engine however many cars attempting 200mph runs are barely in control. I give high points to the stock suspension and aerodynamics on the new Vette.
Old Feb 26, 2014 | 10:18 AM
Papas02C5's Avatar
Papas02C5
Originally Posted by thespymaster
Call me special, and I might be wrong on my .02 cents, but the Hennessey C7 is not RWHP of 700 HP but rather to the crank?
If you look at 36 seconds into the video the spoiler badge on the car says HPE600. The car only has 600 bhp according to Hennessy web site. So subtract the 15% parasitic drag from the driveline it is actually only putting down 510rwhp....
Old Feb 26, 2014 | 10:27 AM
Blackdevil77
But nos was used in addition to that.
Old Feb 26, 2014 | 12:52 PM
JoesC5's Avatar
JoesC5
Yep, a 100 HP shot.
Old Feb 26, 2014 | 12:55 PM
  #33
JoesC5's Avatar
JoesC5
No controversy, just a discussion with different views presented. BTW, as a matter of discussion, there are you tube videos of stock Z06's and ZR1's doing top speed runs of around 200+.
Old Feb 26, 2014 | 03:16 PM
  #34
Blackdevil77
Hopefully we'll see video's of top speed runs with the C7's soon. That'll answer a lot of questions.
Old Feb 26, 2014 | 03:55 PM
  #35
PRE-Z06's Avatar
PRE-Z06
Coefficient of drag is not a constant at different speeds and you must multiply it by the cars frontal area to determine true drag, hope that helps. As mentioned conditions can definitely effect top speed, I heard the ZR1 went 207mph in one test though just like the 0-60 and 1/4 stats from the manufacturer they are an average not best case scenario. Regardless I honestly wasn't impressed with the H/C C7 I saw run at the Texas Mile in the spring even given the conditions.
Old Feb 26, 2014 | 04:19 PM
  #36
Steve Snake Driver
The LT1 dyno-ed using SAE numbers dyno's around ~390 rwhp, not 410 rwhp. Most dyno's use STD numbers.
Bunch of SAE corrected dyno's from Halltech all show higher than 405 rwhp for bone stock A6 LT1s. Different dyno's on different days.
Old Feb 26, 2014 | 04:48 PM
  #37
Blackdevil77
Exactly!
To 200 mph run
Old Feb 26, 2014 | 04:50 PM
  #38
Blackdevil77
What do you believe is the reason for the unimpressive mile runs? Lack of power or CD/downforce slowing the car down at speed?
Old Feb 27, 2014 | 11:42 AM
  #39
PRE-Z06's Avatar
PRE-Z06
I'm asssuming the latter, but I don't personally know the driver so maybe he wasn't driving it to it's full potential.
Old Feb 27, 2014 | 11:48 AM
  #40
Blackdevil77
I can't wait until the weather breaks and people start driving these cars some more. I want to see some texas mile runs and perhaps some top speed runs, similar to what Motor Trend did with Randy and the GT500.
