Software Version?
Old Feb 26, 2014 | 08:23 AM
jdb1218's Avatar
jdb1218
Default Software Version?
I took my C7 in Monday because a piece of the undercarriage buckled on the passenger side. They said it had to be replaced and ordered the part.
While there, I asked them to do the software update for the HVAC/illumination issues. Once completed, my software version says 23427521 but I can't find any information regarding this version.
Does anyone know how this is different from the other version numbers I found on this forum?
Thanks.
Old Feb 26, 2014 | 09:39 AM
BlueOx's Avatar
BlueOx
Wait...your UNDERCARRIAGE buckled?? Could you give us a bit more detail on that one?
Old Feb 26, 2014 | 02:41 PM
kdavis69's Avatar
kdavis69
The dealer updated my software about 3 weeks ago, shows version 23427521.
I would also like to hear more about the undercarriage issue.
Old Feb 26, 2014 | 03:04 PM
kp's Avatar
kp
Mine shows 23427523, late Nov production, I have the non NAV radio so thats why it may be different.
They checked mine before I took it home a week ago and they said it was all up to date on updates. I dont have any IP 'dusk' issues, but my climate control is odd to say the least. From what I read the climate control is normal..
Old Feb 26, 2014 | 08:46 PM
Pete43's Avatar
Pete43
Mine is 23427515... I've not had mine updated yet. Vin# 2107
Old Feb 27, 2014 | 09:35 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Thanks.
software smothware!
What's this "piece of the undercarriage buckled on the passenger side" stuff? Pictures? More information?
Elmer
Old Feb 27, 2014 | 09:44 AM
uwec86's Avatar
uwec86
Is there a place to look up the latest version?
Old Feb 27, 2014 | 11:08 AM
jdb1218's Avatar
jdb1218
Thanks all. I was hoping for a list of issues resolved in this version, so I emailed customer service. If I find anything I'll post it here.
Regarding the undercarriage issue, I should have been more specific. There is a piece of plastic (?) on the passenger side which has buckled a little. It is noticeable when you approach the car from that side.
Attached is a picture.
Old Feb 27, 2014 | 11:09 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
So what are we looking at? It isn't obvious exactly what body part (or area) that pic shows.
Old Feb 27, 2014 | 11:13 AM
jdb1218's Avatar
jdb1218
This is just behind the passenger side front wheel well. I have attached a photo circling the issue; the plastic piece has dipped in the center.
Old Feb 27, 2014 | 11:19 AM
KenHorse's Avatar
KenHorse
Ahhhh.. the liner. I had a feeling that might be what I was seeing. Thanks for the confirmation!
Should be a minor fix
Old Feb 27, 2014 | 12:07 PM
eboggs_jkvl
Moderator emeritus
Ok, liner sounds less horrible!
Thanks for the picture.
Elmer
Old Feb 27, 2014 | 12:16 PM
bimmerborn's Avatar
bimmerborn
How to check for software version?
Old Feb 27, 2014 | 01:00 PM
jdb1218's Avatar
jdb1218
From the home screen, tap settings.
Old Feb 27, 2014 | 01:51 PM
Darkwavemaster's Avatar
Darkwavemaster
Where can I locate the software version number?
Old Feb 27, 2014 | 02:24 PM
time2run's Avatar
time2run
St. Jude Donor '13-'14-'15
Thanks.
If I had to guess, the displayed software number (mine currently shows 23427521) is a compilation of several updates. There are about 25 modules that I can find that will accept software updates and each has a history of numbers as to what was required for the update.
For my Z51 A6 VIN #2498, there are about 15 modules that need some sort of update and each module has a list of specific updates and update codes. There are no dates associated with the update so it's hard to determine if the update has already been applied or are required at this time. My car was produced in late October 2013 and has never been updated so I know it needs a few tweaks.
Attached is the info for one system and again is specific to my vehicle. Please don't ask where I got this because I would have to lie and say it magically appeared.
P16 Instrument Cluster
File Type: pdf
Old Feb 27, 2014 | 02:55 PM
cyberay's Avatar
cyberay
Go to infotainment system settings and select software version. You will find software versions for gracenote, maps, system, etc. The one you would want is for "system". Mine shows last 4 digits of 1791, built 12/19/13 and no updates since.
Ray
To Software Version?
