Anti-sway bar mod
Old 03-08-2014, 10:50 AM
C7 DalyDrvr
C7 DalyDrvr's Avatar
Default Anti-sway bar mod
Opinions please: One of the forum vendors is selling front and rear anti-sway bars matching those on the Z-51. If these are installed on a base model will there be a noticeable improvement in handling? Will they
tend to make the ride stiffer?
Old 03-08-2014, 10:54 AM
leadville1
leadville1's Avatar
Larger Sway bars don't typically make your ride stiffer they just allow less roll. This one of the best mods I did to my M5, in effect it helps with less than adequate spring rates.
Old 03-08-2014, 11:05 AM
GS1960
GS1960's Avatar
If you want to eliminate as much body roll as possible, shouldn't you wait until the sway bars for the Z07 are available?
Old 03-08-2014, 11:20 AM
jim2092
Support Corvetteforum!
jim2092's Avatar
St. Jude Donor '08
On a C6, adding Z51 bars to a base suspension makes the ride rougher on uneven pavement and changes the cornering manners from understeer to slightly oversteer. And yes, it keeps the car flatter in high speed turns. I would be surprised if it was much different in a C7. Going to ZO7 bars on a base car would be even more of the above.
Old 03-08-2014, 12:42 PM
stevebz06
stevebz06's Avatar
Pfadt Racing has been offering adjustable sway bars for C5's and C6's for a while, so I would imagine they'll be offering something for the C7 shortly. If you don't know what you should do with an adjustable sway bar to affect handling the way you want, they'll talk you through it. This will allow you to adjust the handling to what you like rather than accepting whatever the bars give you.
Old 03-08-2014, 12:54 PM
Bigdog2112
Bigdog2112's Avatar
Except that Pfadt recently closed their doors up and are shutdown!
Old 03-08-2014, 01:03 PM
stevebz06
stevebz06's Avatar
OH, great! I wonder what has happened to their unsold stock? Somebody should be making adjustable sway bars: it's not THAT difficult.
To Anti-sway bar mod
Quick Reply: Anti-sway bar mod
