Help ASAP
Old Mar 8, 2014 | 02:57 PM
xmarine99's Avatar
xmarine99
Default Help ASAP
2014 sitting in garage won't start.We set the new time and programed garage door remote.Now car won't start.Dash and nav is fully lit up but no start!Any one got any ideas?
Old Mar 8, 2014 | 02:58 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
No start or no crank?
Auto or manual?
Step on clutch or brake?
Old Mar 8, 2014 | 03:00 PM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
You have the key fob in your pocket. Did you lay it on the work bench?
If it is automatic is it in park?
I just think it is not reading the fob
Old Mar 8, 2014 | 03:04 PM
xmarine99's Avatar
xmarine99
auto,stepped on brake,fob on consol
Old Mar 8, 2014 | 03:05 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
hm... put the fob in the slot on the steering column.
Old Mar 8, 2014 | 03:06 PM
xmarine99's Avatar
xmarine99
no crank and dash lights all lit up
ATX-C7's Avatar
ATX-C7
This ^^^^
TEXHAWK0's Avatar
TEXHAWK0
Did you try plugging the fob in?
xmarine99's Avatar
xmarine99
Tried fob in column same thing also tried other fob
Old Mar 8, 2014 | 03:07 PM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
Try the other fob
I know this makes no sense...make sure you step on brake ,....harder?
Old Mar 8, 2014 | 03:09 PM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
Something is stopping the car from reading the fob. Some safety feature is not allowing it to engage
Move the shifter in and out of park.
xmarine99's Avatar
xmarine99
called dealer they have no idea.Going to come get it monday morning.212 miles on it and dealer is 90 miles away!
Old Mar 8, 2014 | 03:10 PM
ATX-C7's Avatar
ATX-C7
Try starting it on the FOB outside of the car.
xmarine99's Avatar
xmarine99
any harder and i'll break the pedal
Old Mar 8, 2014 | 03:11 PM
eboggs_jkvl
Moderator emeritus
Note to xmarine99: Don't break the damn pedal!
xmarine99's Avatar
xmarine99
with fob in steering column it will shift in to gear so i tried wiggling shifter in case it was neutral safty switch.still no luck
eboggs_jkvl
Moderator emeritus
Interesting idea!
To Help ASAP
Old Mar 8, 2014 | 03:12 PM
eboggs_jkvl
Moderator emeritus
Buttons "up"?
Old Mar 8, 2014 | 03:14 PM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
Boy I am lost. Please let us all know what it is when you find out
CRABBYJ's Avatar
CRABBYJ
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
Access the battery compartment and disconnect the battery and wait 10-15 minutes before reconnecting. Who knows, could reset something.
