Help ASAP
Old Mar 8, 2014 | 03:15 PM
Glen e's Avatar
Glen e
This is how to do a control-alt-delete on a car.....disconnecting batt won't do anything...
Find the battery and do a "GM global reset" GM techs do it all the time.
disconnect both of the cables from the battery
touch them together for 20 seconds or so, wait five minutes and reconnect the battery , positive first and then the negative
Old Mar 8, 2014 | 03:16 PM
zhopper05's Avatar
zhopper05
2015 C7 of Year Finalist
Originally Posted by CRABBYJ
Access the battery compartment and disconnect the battery and wait 10-15 minutes before reconnecting. Who knows, could reset something.
If that doesn't do it, try charging the battery up.
Old Mar 8, 2014 | 03:18 PM
Kent's 05 Coupe's Avatar
Kent's 05 Coupe
Try using the smart phone app Remote Link see if will start
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Starting to think this might be something to try.
Elmer
Old Mar 8, 2014 | 03:20 PM
kevingilmore's Avatar
kevingilmore
follow the manual for adding a key fob with no key fob present
Old Mar 8, 2014 | 03:21 PM
eboggs_jkvl
Moderator emeritus
Did you put the car into "ACC" to do the programming? Asking the obvious....
Did you take it out of ACC?
Elmer
Old Mar 8, 2014 | 03:22 PM
eboggs_jkvl
Moderator emeritus
IMHO, that would be my very LAST thing I'd consider.
Old Mar 8, 2014 | 03:23 PM
sotirisf's Avatar
sotirisf
do this..
take fob, close doors and lock car with fob.
then try remote start.
see if that starts car
Old Mar 8, 2014 | 03:34 PM
eboggs_jkvl
Moderator emeritus
Yo! Marine! Where'd ya go!
Old Mar 8, 2014 | 03:37 PM
xmarine99's Avatar
xmarine99
locked doors then tried remote start.doesn't start.Why does the horn honk twice when i close the door?I'm not pushing anything on fob?
Old Mar 8, 2014 | 03:39 PM
eboggs_jkvl
Moderator emeritus
autolock feature set in options?
Old Mar 8, 2014 | 03:42 PM
NSC5's Avatar
NSC5
On most GM cars the honking indicates you left a fob in the car. Headlights turned on manually is another possibility.
Did you try the reset procedure suggested by Glen?
Old Mar 8, 2014 | 03:43 PM
  #33
xmarine99's Avatar
xmarine99
not sure but would auto lock prevent starting?And if so how to disable?
Old Mar 8, 2014 | 03:46 PM
  #34
xmarine99's Avatar
xmarine99
Didn't try glenn's idea.My luck i'd blow the alt or somethingBesides what would I do if on a trip and it happens?Carry tools for new vette?Guess i'll let dealer figure this out
Old Mar 8, 2014 | 03:48 PM
  #35
eboggs_jkvl
Moderator emeritus
No need, autolock just locks the doors and the honk is the confirmation.
I'm running out of ideas. The last resort is the reset of the car by disconnecting the battery. After that, try charging the battery. Sounds like a call for a flatbed to the dealer might be hovering in the wings.
Elmer
Old Mar 8, 2014 | 03:51 PM
  #36
ATX-C7's Avatar
ATX-C7
Just curious, what is your VIN? Trying to see if early or brand new car.
Old Mar 8, 2014 | 03:53 PM
  #37
Thrill6's Avatar
Thrill6
If it were a FOB issue, you would see a message that says NO FOB DETECTED when you try to start it. My bet is that you killed the battery setting everything up (with the radio on no doubt). Roll it out of the garage and hook up a set of jumper cables..
To Help ASAP
Old Mar 8, 2014 | 03:55 PM
  #38
xmarine99's Avatar
xmarine99
1G1YD2D72E5109282
Old Mar 8, 2014 | 03:57 PM
  #39
NSC5's Avatar
NSC5
Auto lock shouldn't disable starting. This is definitely not a common problem so I wouldn't worry about it happening on a future trip.
What sort of clamps are used on the terminals of the C7 battery? My 2008 CTS is trunk mounted and uses tool-less quick release connectors, just move a lever to release tension and remove the cable.
Old Mar 8, 2014 | 04:01 PM
  #40
Highway 61's Avatar
Highway 61
From: Between Forest Lake and White Bear Lake in the Land of 10,000+ lakes
Did you have a battery tender hooked up? If not, charge the battery back up. You might have just enough juice for lights, but not to start the car. Nothing to lose charging the battery.
