Help ASAP
Old Mar 9, 2014 | 10:41 AM
  #61
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
Originally Posted by xmarine99
I charged the battery and after several hours it started.Will continue to charge till fully charged.Still don't understand why the dash lights would not turn off with dead battery!It and the possible fob problems were just red herrings as one guy stated.Thanks for all the ideas
GReat news! I am so happy for you. We all learned something from this.
Old Mar 9, 2014 | 11:00 AM
  #62
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
When I do anything that requires more than 5 minutes with the electronics, I simply start the car and let it idle while I putter with the buttons. These cars are voracious for juice and they eat batteries like M&Ms.
Elmer
Old Mar 9, 2014 | 11:19 AM
  #63
z51vett's Avatar
z51vett
Are the lights still on if so that would run down the battery oh don't they have run down protection?
z51vett
Doug
Old Mar 9, 2014 | 01:18 PM
  #64
Harry2's Avatar
Harry2
This is an example of the Forum at it's best, members helping each other resolve a problem!
Old Mar 9, 2014 | 01:23 PM
  #65
xmarine99's Avatar
xmarine99
Its auto and the only thing i can come up with is there wasn't enough juice to power a relay to shut off dash lights?I will ask dealer's service dept about it.
Old Mar 9, 2014 | 01:24 PM
  #66
nous defions's Avatar
nous defions
I certainly learned from this. It was an interesting problem, for sure. I'm glad he got the car started.
Old Mar 9, 2014 | 01:40 PM
  #67
eboggs_jkvl
Moderator emeritus
If you don't have one of these, I suggest you get one or get the one from the dealer. I have this unit on both of my cars.
http://forums.corvetteforum.com/1583830839-post6.html
Elmer
Old Mar 9, 2014 | 01:41 PM
  #68
FLYNLO's Avatar
FLYNLO
It kinda shows us how we deal with problem solving when there is automation involved. We would have solved this issue immediately had this been a mid year Corvette because all symptoms would be apparent. But the automation hides symptoms and leaves us grasping at straws!!!....and the solution ended up being the most common and simplest of them all yet we overthink it because the common symptoms are absent.
Glad you got it started. Now put that battery tender to good use!!!
Old Mar 9, 2014 | 01:47 PM
  #69
FLYNLO's Avatar
FLYNLO
I think you may have it backwards...or I am misunderstanding you. It is not a relay to shut off dash lights. There was not enough power to close a relay to engage the starter...leaving your dash lights lit but no starter engagement. There is probably a computer somewhere that needs x amount of amps to "allow" you to start the car. You may have been below that level so it basically locked the start circuit out until you had the proper amount of voltage/amperage.
Old Mar 9, 2014 | 01:52 PM
  #70
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
If it's like the C5/C6, the starter interlock is controlled by the BCM (Body Control Module)
Old Mar 9, 2014 | 02:53 PM
  #71
zo6 08's Avatar
zo6 08
Originally Posted by CRABBYJ
Access the battery compartment and disconnect the battery and wait 10-15 minutes before reconnecting. Who knows, could reset something.
Old Mar 9, 2014 | 03:29 PM
  #72
eboggs_jkvl
Moderator emeritus
Well, he has it running now by recharging the battery. Excellent!
Our job is done here!
Elmer
Old Mar 9, 2014 | 03:44 PM
  #73
Carabajal87108's Avatar
Carabajal87108
Have idea, happened to my boss in her 2012 Vette, are you parked on an incline, either foward or backward? if so the slightest incline will bind trany linkage and wont start. Safty feature for most chevys. Lift car in rear where both tires are off ground try to spin tire back and forth you'll her a knock or pop sound that is trany unbinding. If not there is a safty release in console for trany that will allow it to shift if nswitch is bad. There is also the possibility that when you set the time you activated security system in BCM, on that issue there is a sequence you must do to reset it. Most involve unlocking from pas side removing BCM fuse then going into drivers side and flip key to run then to access past off position you'll hear a double chime letting you know BCM is resetting . If yours has keyless entry after this tep hold unlock and lock button down at same tim till you hear tripple chime, that is telling you it accepts the keyless reader. Chevy secret.
Old Mar 9, 2014 | 08:53 PM
  #74
robertbruce's Avatar
robertbruce
Was it hard to get at the battery? I am glad you got your car started. Putting your car on a battery tender may help. I have been using one for years.
Old Mar 9, 2014 | 10:14 PM
  #75
xmarine99's Avatar
xmarine99
Battery is very easy to access.Above right rear wheel in hatch
Old Mar 9, 2014 | 10:22 PM
  #76
c6miller's Avatar
c6miller
agree, also be sure your fob is not by your iPhone
Old Mar 9, 2014 | 10:33 PM
  #77
blackmagicZ's Avatar
blackmagicZ
And now you know why there is the "battery protection package" offered.
To Help ASAP
Old Mar 9, 2014 | 11:16 PM
  #78
eboggs_jkvl
Moderator emeritus
Post 44 shows the way to get a charge to the battery WITHOUT pulling up the carpet in the rear.
Post 67 shows a really good system to use for post 44.
You do not need to tear **** apart in the trunk to use a battery maintainer on the C7
Elmer
Old Mar 9, 2014 | 11:44 PM
  #79
Virtual Geezer's Avatar
Virtual Geezer
So glad you're up and running again! As others have suggested, get the CTEK battery tender. Plug it in when your Vette's not in use and enjoy complete peace of mind. I had a C5 coupe that never needed a tender in during the 9+ years I owned it. But my '13 GS ragtop does -- it's just a fact of life. There really is a reason that GM offered the 'battery protection' option on the C6 and C7. Best wishes!
Old Mar 10, 2014 | 01:59 AM
  #80
Gr8ful's Avatar
Gr8ful
If the car is in the "Acc mode" all the dash lights will be on but the the car will not start. I found that out by accident.
I thought maybe you held down the start switch for 10 seconds w/o applying the brake to put it in that mode to have the power to make the changes.
Say saying.
