Performance exhaust
Old Mar 14, 2014 | 07:30 PM
RAY P.'s Avatar
RAY P.
Navigator
Default Performance exhaust
I have a 2014 3lt (NOT a Z51) and when set to Sport OR Track, the exhaust indeed does what it is supposed to do BUT after a few moments, the open sound suddenly shuts and goes to the quiet exhaust sound. The only way to get the louder sound to return is to aggressively and briefly accelerate and the through sound returns for a few moments.
I have been told that the sound should never change to quiet as long as the car is in the Sport or Track mode.
Can someone help and let me know which are the facts. Remember NON Z51 but the car DOES have the performance exhaust option.
Ray
I think i must have asked the wrong question
does anyone out there have a 2014 C7 Stingray that has the performance exhaust and if so,,,,,,,does the great sound of the Sport and/or Track mode stay on as long as your car is in either of these two mode OR
does it shut off after a few seconds . in other words,, does anyone have the same issue as i stated above. i am not looking for solutions, only identifying anyone with the same concerns
Ray
Old Mar 14, 2014 | 08:28 PM
Zymurgy's Avatar
Zymurgy
Moderator
You have to change a setting. Driving Mode > Engine Sound Management > set to OFF.
Old Mar 14, 2014 | 08:33 PM
C7pimp's Avatar
C7pimp
It works great, but it will quiet down under light throttle.
Old Mar 14, 2014 | 08:34 PM
bgood's Avatar
bgood
Cruise-In IV Veteran
St. Jude Contributor
Is the car going into V4 mode?
Old Mar 14, 2014 | 08:40 PM
RAY P.'s Avatar
RAY P.
Navigator
Originally Posted by bgood
is the car going into v4 mode?
i have watched the display to see if that may be the problem and i makes no difference
thanks for the reply
Old Mar 14, 2014 | 08:41 PM
RAY P.'s Avatar
RAY P.
Navigator
It makes no difference
Old Mar 14, 2014 | 08:51 PM
FLYNLO's Avatar
FLYNLO
I seem to remember reading that this in fact does keep the valves aft of the mufflers open but does not control the valves ahead of the mufflers???...meaning that you still aren't getting wide open sound unless you stomp on it. Is this true?? I do not possess my car yet so I am speculating on what I have read....
Old Mar 14, 2014 | 08:55 PM
Zymurgy's Avatar
Zymurgy
Moderator
The valves ahead of the mufflers are only used when in V4 mode. Both exhaust systems (standard and NPP) have the eco mode valves. Only the NPP have the aft muffler valves which open up a less restricted and louder path.
Old Mar 14, 2014 | 08:58 PM
Zymurgy's Avatar
Zymurgy
Moderator
Here's some photos (thanks to talon90) of the NPP (and ECO valves). The ECO valves are before the mufflers and the NPP are the valves after the muffler - right before the exhaust tip):
The NPP valve opens up a less restrictive path through the muffler that results in less back-pressure, more HP and torque and a louder exhaust sound.
The non-NPP exhaust has the ECO valve and only a single outlet pipe from the muffler that the splits into the 4 exhaust tips. No NPP valve.
Old Mar 14, 2014 | 09:02 PM
RAY P.'s Avatar
RAY P.
Navigator
Originally Posted by zymurgy
you have to change a setting. Driving mode > engine sound management > set to off.
i did, makes no difference
Old Mar 14, 2014 | 09:05 PM
Zymurgy's Avatar
Zymurgy
Moderator
Visually check the position of the butterflies in the NPP valves. Are they open or closed? (car running, engine sound management set to off).
Old Mar 14, 2014 | 09:11 PM
N2TU's Avatar
N2TU
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18
and learning!
Old Mar 21, 2014 | 02:43 PM
Cruiter's Avatar
Cruiter
On order: Torch Red Z51
It does get quieter after a short distance. This is what mine sounds like in the garage when she wakes up in the morning. My neighbors get to hear it too . Fortunately the closest one on the garage side is a gear head .
Ray
Ray
Old Mar 21, 2014 | 02:52 PM
BigJoe's Avatar
BigJoe
When I switch to Sport mode while driving the exhaust gets instantly louder and stays that way. It gets even louder if I accelerate briskly then quiets down when cruising, as you would expect. But i doesn't get as quiet as it would if I switched back to Touring or Eco. I do not have the Driving Mode > Engine Sound Management > set to OFF.
Sounds to me like the OP's car is operating normally.
Old Mar 21, 2014 | 04:20 PM
Buzzardz_vette's Avatar
Buzzardz_vette
AFM is not an issue in Sport or Track mode, at least with mine. For 7spd man, it only works in Eco mode. In the Auto 6, I believe it works in touring as well, not sure about Sport or Track.
". Normal with automatic
transmission: The engine uses
8-cylinder mode when
accelerating, but changes to
4-cylinder mode when coasting.
. With manual transmission:
Active Fuel Management only
active in Eco Mode.
. Off in Manual mode with
automatic transmission unless in
Eco mode"
I have the exhaust turned off so it stays loud in all modes, however, my M7 doesn't get real loud unless you step on the gas.
To Performance exhaust
