Noise driving me nuts
Old Apr 29, 2014 | 01:53 PM
Eodgunny's Avatar
Eodgunny
My rattle was the passenger side clip that the roof snaps into when stowed...
Old Apr 29, 2014 | 02:39 PM
drace99's Avatar
drace99
Default Thanks
Thank you for the help...I will check these places too.
Old Apr 29, 2014 | 02:41 PM
xp800's Avatar
xp800
I notice that both the front hooks make noise on mine too only when the rood is stowed. I can reach back and hold the roof panel and the rattles will stop.
I also notice that the rear supports on the back wall that hold the horizontal roof pins are pretty loose and may rattle.
I have not tried to permanently fix.
Did you find a fix?
Old Apr 29, 2014 | 04:11 PM
rdrnr's Avatar
rdrnr
Originally Posted by kdavis69
http://forums.corvetteforum.com/c7-g...heres-how.html
also, I don't know if this is what you're hearing but I noticed a similar rattle which turned out to be the passenger seat belt buckle hitting against the b-pillar. I pulled the lower part of the seat belt housing forward, in front of the seat back, and the rattle stopped.
Old Apr 29, 2014 | 07:10 PM
C7Joy's Avatar
C7Joy
Another thing to look for: see if the passenger seat is elevated to the point where the top of the seat is in contact with the "roll bar". Wifey had mine way up there. The car has been solid as a rock even on our crappy, hole filled roads.
Old Apr 29, 2014 | 07:32 PM
Eodgunny's Avatar
Eodgunny
Did you find a fix?
I haven't had a chance yet. I'm hoping it's just a loose screw.
Old Apr 29, 2014 | 07:52 PM
kp's Avatar
kp
This just happened to me lol, my wife is short and had the seat cranked up. For a while every time I'd hit some bumps it sounded like sandpaper rubbing on something. Thought it was the battery styrofoam cover at first but I took that out and it still did it. Then I happened to notice the passenger seat back moving when it was making the noise and sure enough the top of the seat was jammed up against the halo.
Old May 2, 2014 | 06:42 AM
onyx_z71's Avatar
onyx_z71
I fixed the same issue on two different C7s. Awful squeaky racket. It was due to the rear quarter glass rubber gasket rubbing on the rear quarter panel - on BOTH sides. I found the thread mentioned above, and I would never have believed the noise was coming from outside the car.
But I solved it by REMOVING shims at the first screw in my picture below to create a GAP between the window gasket and body panel.
This was mentioned above, but this looks like it shims the interface tighter rather than removing the interference as I did:
My approach:
Push here to see if it squeaks:
If it does, remove this screw:
Remove at least 1 shim:
And you want to create a small gap, then do the press-squeak test again. If it does remove another shim (they were different thickness on mine):
Thank you for this post as I removed one shim and the rattle behind my head is now gone. The panel fitment is still good too.
Old May 2, 2014 | 08:04 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Originally Posted by kp
+1
If the belt is just hanging next to the seat the buckle will hit the plastic seat belt over bumps. Its pretty loud and not a normal little creak/rattle.
Had that rattle over a bump and did not know why until a forum poster mentioned the seat belt Solved the issue with a seat belt pad! Easy to test, just tie a rag around the metal buckle and see if it stops.
