Noise driving me nuts
Old Mar 25, 2014 | 08:42 AM
drace99's Avatar
drace99
Default Noise driving me nuts
I have had my C7 only 2 weeks and I hear something coming from the inside, maybe on the passenger side rear hatch...it only seems to happen when I hit a bump or dip in the road. Has anyone else had this? The best I can describe is it sounds like the plastic is loose.
Old Mar 25, 2014 | 09:18 AM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
There was a post in C7 General about the rear hatch popping over bumps, along with a fix and pics about putting extra gasket under the front of the hatch. I haven't found it yet, but a search will help you.
Old Mar 25, 2014 | 09:21 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Hey Drace99,
I apologize that you are experiencing concerns with your Vette. I would be more than happy to look into this further for you, although I cannot guarantee the outcome. Please provide me with your contact information, VIN, and your preferred dealership via private message, if this interests you. Hope to hear from you soon!
Jennie R.
Chevrolet Customer Care
Old Mar 25, 2014 | 09:33 AM
kevingilmore's Avatar
kevingilmore
is the passenger seat is all the way back on the stop, move it up an inch.
Old Mar 25, 2014 | 09:36 AM
harmonyp's Avatar
harmonyp
Just looked, we're at 1400 miles. First 1K miles, I think we had a total of 3 rattle noises in misc. places in the car. Each lasted a handful of drives then disappeared with no action. Right now - no noises for easily last 10 drives. Just a FYI.
Old Mar 25, 2014 | 10:00 AM
kdavis69's Avatar
kdavis69
http://forums.corvetteforum.com/c7-g...heres-how.html
also, I don't know if this is what you're hearing but I noticed a similar rattle which turned out to be the passenger seat belt buckle hitting against the b-pillar. I pulled the lower part of the seat belt housing forward, in front of the seat back, and the rattle stopped.
Old Mar 25, 2014 | 10:01 AM
shaan's Avatar
shaan
I have the same problem, but only over heavy bumps i still cannot figure it out
Old Mar 25, 2014 | 10:10 AM
-CM-'s Avatar
-CM-
Is it the passenger seat belt buckle hitting the seat back?
Old Mar 25, 2014 | 10:21 AM
kp's Avatar
kp
+1
If the belt is just hanging next to the seat the buckle will hit the plastic seat belt over bumps. Its pretty loud and not a normal little creak/rattle.
Old Mar 25, 2014 | 10:34 AM
Rfong's Avatar
Rfong
My C7 has a vibration rattle only at freeway speeds on rougher pavement. I have isolated the source in the rear hatch gasket, more specifically on the passenger side forward area of the gasket. It is not the gasket itself rather it is where the interior roof panel wraps up and around the roof structure and is covered by the rubber hatch gasket.
To fix this rattle, lift the rubber gasket to expose the edge of the interior roof panel. Pry the panel away from the body frame and stuff some felt or padding material between the two hard surfaces. I have not eliminated the rattle but decreased its frequency by inserting felt at 4 different locations along the gasket area. I'll keep adding more felt until I can silence the rattle 100%.
Old Mar 25, 2014 | 10:36 AM
drace99's Avatar
drace99
Default I will check
Thanks for the input, I will check on the seat position and the seatbelt.
Old Mar 25, 2014 | 01:26 PM
BADA BING's Avatar
BADA BING
i have heard the same rattle, sounds like it is coming from the passenger side of the trunk where the metal loop is you attach the shade. i will also look at the seat belt to see.
Old Mar 25, 2014 | 06:50 PM
WantaC7's Avatar
WantaC7
Yip mine also has it, mostly on the freeway, it happens when the wife is in the car and her seat is not all the way back ( also happens when she is not inside )
Old Mar 25, 2014 | 07:19 PM
Rfong's Avatar
Rfong
When you hear the buzzing rattle, have your wife unbuckle her seatbelt, contort herself around facing rearward and pull on the upper edge of the gasket until the squeak stops. That's how I identified the location while my friend was driving.
I inserted 1/4" strips of felt with adhesive backing but I have not found the exact spot yet. I have managed to diminish the sound of the rattle but it is still there but not as often. Trouble is, it only happens on certain rough stretches of freeway so rattle testing is not convenient or easy to do.
Old Mar 25, 2014 | 08:10 PM
TheYoungster's Avatar
TheYoungster
The noise is coming from the foam battery cover under the rear carpet. Remove the foam cover and the noise will go away.
I haven't figured out how to get it to stop with the foam piece in place. If anyone has a fix with pictures, it would be cool
Old Mar 29, 2014 | 11:34 AM
drace99's Avatar
drace99
Default so far so good
I haven't been able to drive my vette until yesterday, but I moved the seatbelt and the rattle seems to be gone...I will also check the gasket and battery cover too. Thanks
Old Apr 29, 2014 | 12:13 PM
drace99's Avatar
drace99
Default not the seatbelt
The noise has never really stopped, I thought it was the seatbelt, but it is not. I think it is the rear hatch...bringing it to Kerbeck this Friday, hopefully they can fix it. I have noticed it is worse on cooler days/temps.
To Noise driving me nuts
Old Apr 29, 2014 | 12:38 PM
xp800's Avatar
xp800
I fixed the same issue on two different C7s. Awful squeaky racket. It was due to the rear quarter glass rubber gasket rubbing on the rear quarter panel - on BOTH sides. I found the thread mentioned above, and I would never have believed the noise was coming from outside the car.
But I solved it by REMOVING shims at the first screw in my picture below to create a GAP between the window gasket and body panel.
This was mentioned above, but this looks like it shims the interface tighter rather than removing the interference as I did:
My approach:
Push here to see if it squeaks:
If it does, remove this screw:
Remove at least 1 shim:
And you want to create a small gap, then do the press-squeak test again. If it does remove another shim (they were different thickness on mine):
Old Apr 29, 2014 | 01:04 PM
jwbert's Avatar
jwbert
If the rattle is from that plastic cover at the top of the rear window, as
some suggest, GM redesigned that part at some point in the production run to try to fix that. Mine at 9950 had the new part, still
rattles on bumps when very cold but otherwise not at all. Suggestion from the Quality control supervisor at the plant was to ask your dealer
to replace that part it rattle is present.
Old Apr 29, 2014 | 01:19 PM
Magister Ludi's Avatar
Magister Ludi
Thank you all for taking the time to demonstrate your fixes.
Very much appreciated.
