Preparing for arrival
Old Apr 11, 2014 | 07:14 AM
snappy2u's Avatar
snappy2u
Default Preparing for arrival
My TPW is 4/14!...YEAH!
Decided to have the garage floor professionally prepared and coated.
Brown/tan/mica flake....stunning! Installed a "Container Store" garage wall system, powder coated grey. Starting to come together......
more pics when I can actually get back into the garage
Mark
Old Apr 11, 2014 | 07:30 AM
87C4_4spd's Avatar
87C4_4spd
Very nice! I need to get mine done some day. How long do you have to stay off it?
Old Apr 11, 2014 | 07:48 AM
snappy2u's Avatar
snappy2u
They started work yesterday and will finish today...should be able to go in tomorrow. 5 coats (3 base and 2 clear) 20 year guarantee
Old Apr 11, 2014 | 08:17 AM
ATX-C7's Avatar
ATX-C7
Maybe paint the baby blue posts a different color
Old Apr 11, 2014 | 09:03 AM
Corgidog1's Avatar
Corgidog1
What color is your car?
Old Apr 11, 2014 | 09:11 AM
dwbaalmann's Avatar
dwbaalmann
I'm guessing it's a boy. Nice to see the nursery coming together. Congrats to the OP on the new arrival.
Old Apr 11, 2014 | 09:32 AM
snappy2u's Avatar
snappy2u
LOL....that's the cameraflash...walls are white
Old Apr 11, 2014 | 09:34 AM
snappy2u's Avatar
snappy2u
2LT, NRB, Kalahari, 7 spd M, NPP, red calipers, Z51 spoiler.....wife bought me a cover already!....can't contain myself....LOL
Old Apr 11, 2014 | 10:28 AM
cor28vettes's Avatar
cor28vettes
Default Congrats on your new arrival
You did right in preparation
Old Apr 11, 2014 | 11:03 AM
SevenTurns's Avatar
SevenTurns
St. Jude Donor '13-'14-'15-'16
Looks Good ! What product are you using ?
Thanks,
Jim
Old Apr 11, 2014 | 11:25 AM
snappy2u's Avatar
snappy2u
Thanks,
Jim
Hired a local company to handle it correctly:
Supply and install our 5 coat 100% solids industrial strength epoxy polymer system. This consists of 2 base coats of industrial strength epoxy polymer, 1 full chip coat - [ the color will be "Chestnut with Mica" ] and 2 clear coats of our 100% solids polyhybrid gloss finish. The floor will be chemically resistant and UV stable. The finish will be seamless, highly durable and simple to clean.
Old Apr 11, 2014 | 12:33 PM
Zymurgy's Avatar
Zymurgy
Moderator
What kind of prep did they do before putting on the first coat?
Old Apr 11, 2014 | 12:38 PM
snappy2u's Avatar
snappy2u
Here's the description of the entire process..3 men 2 full days:
Garage Floor: [ The scope of work will include the foundation stem walls ]
Grind concrete as needed to remove the existing cream layer and surface soil. This will open the pores of the concrete to accept the coatings. [ This will allow the base coating to penetrate deep into the concrete for an unbreakable bond. Hot tires will not compromise the finish ] Repair cracks and divots with polymer modified epoxy compound to smooth out the floor.
Please note that we will bring the coating out beyond the garage door and over the lip of the apron to provide the finished look of a slab. This gives the floor a strong and pleasing appearance.
There are several major factors that influence the strength of a floor coating. First,the ability of the coating to penetrate into the pores of the concrete for an unbreakable bond is critical. This will allow the coating to remain secure especially under the trial of hot tires. Second is the solids content of the epoxy polymer - the higher the solids content, the stronger the coating will be. We use 100% solids, so it is the strongest available. Third is mil thickness, that is the reason we apply 2 base coats and then gain more strength and durability by broadcasting a complete and full coat of poly acetate vinyl paint chips.
The work will take 2 days to complete. You will be able to walk on the floor the following day. Please wait 48 hours before parking any cars on the floor.
Old Apr 11, 2014 | 12:43 PM
jr3's Avatar
jr3
Paint the floor white or light gray.
Old Apr 11, 2014 | 05:34 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
That's gonna be first class.
Old Apr 11, 2014 | 05:47 PM
Zymurgy's Avatar
Zymurgy
Moderator
Is there some type of non-slip treatment?
Old Apr 11, 2014 | 06:45 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nicely done
To Preparing for arrival
Old Apr 11, 2014 | 10:07 PM
Mecholova's Avatar
Mecholova
Looks good Snappy! But with as much work that went into its preparation, I hope you know that cars not going to be in there much
Old Apr 12, 2014 | 04:10 PM
snappy2u's Avatar
snappy2u
Sooo true!!!
Old Apr 12, 2014 | 04:11 PM
snappy2u's Avatar
snappy2u
Yup, they added a bit of slip resistant additive
