I am looking at buying a C7 ZO6 . My understanding is that the ground clearance is 1" less than the Stingray. I presently have a 2008 C6 and the front dam drags already when I go in and out of my driveway. If I buy a ZO6 I will likely not be able to get it into my driveway. My question is: "Does anyone know of a company that makes a piece of rubber that fits into a curb to enable easy entry in and out of a driveway. I have seen them before but I don't know where they are available. Thanks. John Comer
The air dam on your '08 is a wear item, which is even addressed in the Owner's Manual. It hurts absolutely nothing when it drags. I've never understood why so many C6 owners are obsessed with trying all manner of things to stop it from ever touching the ground.
For reference the air dam on my '08 always drug, pretty badly, going into and out of my driveway. The air dam on my new C7 doesn't touch going either way, so even if the C7 Z06 is an inch lower it's not a problem.
Until you get that new C7, quit worrying about the air dam dragging on your C6 as it's hurting nothing, and it's very cheap and easy to replace if needed.
I have not used these but have read reviews online from people who like them... https://www.bridjit.com/
I actually did more research and found that there is a company in Alberta that makes a curb ramp. I should have done more research before I posted. I am sure that with more work on the internet I can find a company in the US that makes such an item. Seems like it would work great although my neighbors might not like the look.
I'm trying to understand why anyone would spend $300 or more to prevent wear to a $100 part that's meant to scrape and wear out. That makes no sense.
Not true. The ZO6 has a carbon fiber dam that is not flexible. I just got that info from the Corvette Museum folks this morning. That is the problem. The flexible dam on the C6 that I have just scrapes with no problem.
The air dam underneath the front end and the CF splitter are two very different things at two very different heights.
The reduction in ground clearance may be from other areas. They will probably use the same air dam that is used on the base car, but the Z06 will have a front splitter that extends down lower under the nose of the car. That will decrease the approach angle, thus you might be dragging it before the air dam ever drags. If you get the optional aero package that comes with the side skirts, then it is possible that you could high center your Z06 on a speed bump, etc.
I drag the splitter on my C6 Z06 every time I drive out onto the street and return. It's made of a pliable rubber like material so it only scuffs the bottom, that is easy to file to remove the fuzzes.
But, it is easy to damage on a concrete curb stop in a parking lot or a deep gutter. The splitter can be removed if it causes you too much of a problem.
Don't know if they are doing it with the C7 Z06, but GM lowered the C6 Z06/ZR1 a half inch from the factory vs the base C6.
From the C7 Z06 photos it appears that the base Z06 will have a splitter made of the flexible rubber like material and the optional aero packages will have the more rigid carbon fiber splitter(like the C6 ZR1, that is very expensive to replace).
Well I had a trailer company about 5 miles from where I live ( who works with different thicknesses of metal ) and had them fabricate 2 --1/4 " X 12" X 36" steel sheets of metal and I lay them in my driveway such as they are 65-66 " apart on centers !!! Since the car has a backup camera I use it to center the car when backing the car down the driveway !!! The driveway is flat but slanted from the far side of the sidewalk to the street so I only need the ramps backing out and not driving up the driveway !!! They probably weigh about 30-40 lbs a piece !!! I haven't put them on a scale to know the exact weight !! Not likely you would ever bend these but you can always turn them over !!! Cost about $150 for both sheets of steel !!! wayne
I can't speak for the C7 but for the C6, the air dam acts (for me) as an "early warning system." It is expendable. But I'd rather not "expend" or crack the radiator supports immediately beyond them, which is easy to do. I don't know if that's the same design for the C7---someone will tell me, or I can crawl under and take a look the next time.
As to the splitter, that's also an expensive item on most Corvettes and I've heard of several being chipped or otherwise damaged. Not a good thing. Let's hope the preventive measures for a driveway work so nothing is damaged.
Lots to consider before buying the 2015 ZO6..ground clearance and money. I think I can fix the ground clearance.
Bought this product before my C7 was delivered. Does exactly what it is supposed to do. No rubbing of the front air dam when entering the driveway. I would recommend it without reservation.
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
just get the stall mat at Tractor Supply...$35...4' x 6' x 1" mat...cut into three 6' x 16" foot sections and lay them across your approach....here's mine...works like a charm.....ignore the weeds ..... one of the benefits of a $13k paver driveway
bring a friend when you buy one...it weighs over 100 lbs and is a pistol to move around and load into a vehicle...get store help too! oh, you will need a good saw to cut it up.
First off, my highest recommendation on the owner, and his product.
But, I didn't get one. Reason is this. I called the owner (sorry, can't remember his name). I left a voicemail, and he got back to me within minutes.
I told him my Corvette drug some on the driveway, and I wanted his bridge.
He asked me to send him several digital closeups, of my driveway, where it meets the road. I did.
Then, he called me back, to tell me the bad news. His product does not work, on every driveway.
There are some with different angles, and different curb structure for rain water to flow.
He said, after looking closely at my driveway, that his product would not help.
He apologised to me.....
Thing is, he could have sold me one, I was ready to order. I so admire his honesty in this. I find it rare these days.
He gave up a sale, but left me very impressed with his integrity.
So, take some pictures of your driveway, and give him a call. He'll most likely ask you to email pics, and he'll then tell you if your money will be well spent or not.
For me, its not about scraping the front air dam. I have a problem with the height of the curb on my driveway with all my cars, including my Durango and my wife's CTS. Some "rolled curbs", such as mine, are extreme and will jar your teeth. I wanted to modify the curb by cutting it down, but the township won't allow me.
The solution: Bridjit. https://www.bridjit.com/ I love these things. They come in 48" sections and I have 3 sections totaling 12 feet. They stay in place because they're are heavy and that also makes them virtually indestructible.
Good luck,
Don
I had a similar experience with Bridjit. They were very careful to insure that their product was a match for my curb dimensions before accepting my order.
Once they saw the photos that I sent them, they assured me that I would be happy with their product. Then it was just a matter of how many to buy, i.e., 8' or 12' wide.
