How many times do you think I've had the fuel door open during the last 34,000 miles I've driven my 09 Z06? What's your point?
Where does it say anything different than what I posted?
Oh, and the owner's manual goes into additional detail as what fuel is required in my Z06, as it does for the base C6 and the ZR1, as well as it does in the owners manual for the 2014 C7. How many times have you looked at the owners manual that is in the glove box of my Z06?
BTW, the sticker on the inside of my fuel door does not say "Use what ever gasoline that the Corvette forum tells you to use." and I doubt it says that on the inside of the fuel door on the C7.
Well, if you actually had a C7, you would see it says 'Premium Fuel Recommended'. It does not say Premium Fuel Required.
Premium fuel recommended is pretty much the industry std these days per the legal depts.. If they said required, you'd have people freakin out when they could not find it, and sitting on the side of the road being too literal. So it is "recommended" but what they all mean is "this car is tuned and made for premium fuel, use less when only in a pinch" It does not mean run 87 as a practice.
We are on a C7 forum talking about a C7.
If you read the Owners Manual, you would see it says:
Use premium unleaded gasoline
with a posted octane rating of 91 or
higher. If the octane is less than 91,
you could damage the engine and
may void your vehicle warranty.
So, follow the Owners Manual which was written specifically for the C7, or follow a generic sticker on the gas door? I'll follow the Owners Manual.
Is that your definition of 'recommended' or what? I trust that the engineers did quite a lot of testing to make sure the fuel mapping was finalized properly when running fuels with less than 'Premium' octane levels. Even though you are pumping what you think is Premium from any pump, how do you know it actually is? The 87 has likely been tested sufficiently to determine there is no problem running it. As I said before, even Gm can't decide what to say because what is written in the manual and on the fuel door label are different.
And if you own a C7, then you should read your owners manual where it says, on page 9-51...
"Use premium unleaded gasoline with a posted octane rating of 91 or higher. If the octane is less than 91, you could damage the engine and may void your vehicle warranty. If heavy knocking is heard when using gasoline rated at 91 octane or higher, the engine needs service." It says use(that means it is REQUIRED") and it says if you use gasoline that is below 91 octane, you could damage the engine. Is that so hard to understand?
Premium fuel is REQUIRED for the C7. GM does not say it is okay to use any gasoline that has a posted octane of less than 91. In fact they warn you that if you do use a gasoline with a posted octane rating below 91, you could damage the engine and you could void your warranty. Is that clear enough for you?
You dont need premium fuel owned 17 corvettes the later models surely can use reg gas the earlier models just spark knocked if fuel grade was too low
Direct injection on the new engines means they can run a higher compression ratio - 11.5:1 in the LT1 vs 10.7:1 in the LS3. I wouldn't risk running 87 octane on a regular basis in that engine. Typically the cost of premium fuel is $.30/gallon more than regular. The cost is negligible, especially when you consider the cost of the car itself.
On the C6 Z06 and ZR1, where they require 91 and recommend 93, GM goes into detail on what to do if you do have to put in gasoline that is below 91 in an emergency.
But when they say 'Recommended' it means you are not required to use it.
You think that GM should print the entire owners manual on the sticker that's on the fuel door?
I am leaving on 8000 mile around the USA trip next week. I researched availability of premium fuel along my route. Vast stretches of state highways through Utah and Wyoming have no premium fuel available. I am concerned due to the extreme elevation climbs I will make across great divide and in Yellowstone park. I'm sure the car has knock sensor but if I use regular fuel and keep my foot out of it will I be OK? Would anyone recommend an octane booster to take along with me and would that help?
I would check Google Maps or the equivalent and see if there is a top tier gas stations along your route and plan accordingly !!! Wayne
If you have an automatic you will be running on 4 cylinders cruising down the highway anyway most of the time. I just mix octanes when I have to.
i was just thinking that when i got to your post but if you do want a o. boost use 104 you can buy it in just about any auto store and you ''can '' feel the diff. have a safe trip
