Why does GM limit the top speed on the C7?
St. Jude Donor '08
I have just checked the Engine Control Module settings (tune) on both an auto and manual 2014 C7. In both cases it shows a Speed Limiter of 135 mph and says "Speed at which fuel delivery is disabled."
Not having driven a C7 above that speed I cannot verify that information.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
Rev limiter 6700 RPMs controlled by fuel cut off
Speed limited 186 MPH controlled by throttle option.
I don't have my 2014 downloaded into my files yet but I'm going to take a SWAG and say Rev and Speed limiting are in there too.
Both can easily be edited to higher numbers but those are the settings coming from the factory.
I also had rev and speed limits on my 98 Camaro with the LS1 engine.
Elmer
St. Jude Donor '08
I bought an 05 that came with a DVD that showed a video of the car on the autobahn at 186mph
Received 1,985 Likes
For all the poster who find the limiter, if it is there........ a tuner can most likely correct that. Other then running the "mile events" not sure where any of this would make a difference. As someone posted changing is gearing 5 & 6 th would be needed too.
I do remember years ago a C5 Z06 I think..... ran like 195....... They put duct tape of the hood and pushed the mirrors back and it went over 200.
So you Andretti types may be able to test that limiter with a little duct tape.
#33
#35
Below is the speed limiter table from a stock 2014 C7. As you notice I never said it could not go over 135 mph.
Attachment 47804376
Attachment 47804376
Michael
#36
Attachment 47804376
But BS is thinking that not many would buy a C7 if it couldn't go over 135 mph.
Attachment 47804376
#37
C6Z06 LS2Edit cal limiter:
The C7 in HP Tuner GMLan:
#39
Attachment 47804376
Attachment 47804376
Seems like there is someone watching us all the time, well they are trying.
