Pissed
Old May 8, 2014 | 04:04 PM
air86's Avatar
air86
Default Pissed
Well apparently I ran over a bolt so I guess im about 1000 out for a new rear tire f***. Its in the center of the tire so I can only hope for a patch
Old May 8, 2014 | 04:06 PM
Sallye M's Avatar
Sallye M
22 Hypersonic Grey HTC
one patch permitted for michelin pilot super sport zp
good luck -
Old May 8, 2014 | 04:07 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Shouldn't be a problem to patch the center of the tire, unless it's a large diameter bolt?
Don't sweat it
Old May 8, 2014 | 04:11 PM
Zymurgy's Avatar
Zymurgy
Moderator
Proper repair is a combination patch/plug (and only after the tire is examined to make sure there is no structural damage):
Michelin (and other manufacturers) run flat repair recommendations:
Old May 8, 2014 | 04:12 PM
runutzzzzz's Avatar
runutzzzzz
Wheel and tire warranty... Yes it cost you $700 but you'd spend $400 on one tire if you had to replace it.
Old May 8, 2014 | 04:13 PM
yell03's Avatar
yell03
That sucks, bet you have some sort of new tire warranty from Michelin
Old May 8, 2014 | 04:18 PM
Zymurgy's Avatar
Zymurgy
Moderator
Cost for a new one is way less than $1000 (this is the Z51 tire):
Old May 8, 2014 | 04:26 PM
rsl2715's Avatar
rsl2715
Thanks for the tire cost was wondering what they would cost.Will make sure Discount Tire will match it.R
Old May 8, 2014 | 04:42 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
Bet your happy you had run flats to get you home
Old May 8, 2014 | 05:14 PM
speedlink's Avatar
speedlink
Is wolfdogs on this forum. He was on C6 forum. He's the resident expert on tires!
Old May 8, 2014 | 05:19 PM
air86's Avatar
air86
It still has or had 24 psi in the tire but i only noticed because it was 10 less than the other 3. I received an onstar report telling me with a low air warning but i dont think the vette tells you ntil 20 psi or at least that was the threshhold for my 08. This just makes me mad because i didnt run any major road hazard item another thing is the entire way to the dealership the psi increased so it tells of a small leak that happens when the car sits. I was never offered a tire and wheel warranty. I know they weren't offered on my c6 for the eagle f1 emts
Old May 8, 2014 | 05:22 PM
Modshack's Avatar
Modshack
What good is a post here without DRAMA??....
Old May 8, 2014 | 05:46 PM
mjw930's Avatar
mjw930
That sounds like an easy inside patch. Find a Discount Tire, get the tire patched and buy their tire warranty for about $50/tire so you never have to worry about it again.
Old May 8, 2014 | 05:48 PM
tentorium's Avatar
tentorium
The one extra I sprung for while sitting in the finance office. And sure enough, not even 700 miles down and my rear tire has a penetrating injury.
Drove to dealer with warranty papers and it was replaced, not repaired.
And WHEN it happens again, it will have more than paid for itself.
Old May 8, 2014 | 05:49 PM
Litumup411's Avatar
Litumup411
I have 2 patches on the same tire. Dealer may patch one time, but second time I went to a local proprietor. Both instances, I caught it before the tire deflated. First one happened right before I pulled into my garage (thought I had an air suspension!). Second one was a screw that I noticed as I was doing a walk around. I think the key is not to drive on it once you notice the drop in air pressure, unless you need to. Otherwise, if you drive on it and utilize the run-flat feature, the inner sidewall will sustain damage and the tire will need to be replaced.
Old May 8, 2014 | 05:56 PM
air86's Avatar
air86
Too late i went to the dealer because i knew they would have the right equipment for a run flat. I had a nail in my 08 emt and alot of places turned me away because they didnt have the equip to deal with me
Old May 8, 2014 | 06:21 PM
Patriot77's Avatar
Patriot77
Don't feel too bad. About a thousand years ago I owned a Nissan 300ZX and was cruising down the road behind a junky old pickup truck when a bucket blew out of the back end of his pickup and hit my hood and also windshield going about 65 mph. I can't even put into nice language how I felt. I could have "strangled him". But of course he never even saw it happen and never even stopped.
To Pissed
Old May 8, 2014 | 06:30 PM
mjw930's Avatar
mjw930
I have no idea where you live so there may not be a Discount Tire near you but trust me, they have everything needed and the experience to deal with any runflat issue.
Glad the dealer was able to make things right. I hesitate going to the dealer for tires, it's not their core competency. I like specialists. But, if you live in BFE then they may be your next best choice.
Old May 8, 2014 | 06:44 PM
air86's Avatar
air86
I can close this post with a smile. Tire was patched and cost was minimal compared to buying another tire. From the look at the bolt as I had a clear view of it in the driveway it was a hex bolt with a big head. I thought the hole would be way too big to patch. Luckily it was in the first deep groove to the outside.
I got frustrated because with 700 miles and already thinking I needed a new tire because I know patching runflats can be frowned upon.
Old May 8, 2014 | 06:48 PM
air86's Avatar
air86
But its people like that who don't secure their s*** which causes road hazards such as this bolt. It angers me that people don't care about others around them.
