Not so fast, your car is not a Z51 so how do you know?
Not sure why the OP wants to do this. I imagine they want to run all season run flats which are only available in the smaller size but a little context might help. We do know that factory 18's will not fit on the front on a Z51 without repositioning the wheel weights. I can't find the thread on the topic but I recall reading it.
I like the Z51 wheels, but I want a spare set for long trips. All season non run flats. The wifey wants a softer ride so non run flats and a little more side wall with the smaller rims should do the trick.
I was agreeing with the first comment from mjw930 mainly, about the confirmation of fitment being likely incorrect..
I put 18/19 TSW Panoramas on my z51 and they fit no problem. I would think Nurburgrings would be the same. Make sure to order the nuts with the TPS, they come separately.
