Engine misfire
Old May 18, 2014 | 09:04 PM
mike13403's Avatar
mike13403
Default Engine misfire
Started the car up tonight and it sounded ruff, I pulled it out of the garage to warm up and the check engine light started flashing, service rear axle and service stabiltrack. I hit the On star button an they run a check and said it is an engine misfire any info on this .My vin is 4795 I thought the rear end issue was fixed anyone have this happen.
Old May 18, 2014 | 09:13 PM
slief's Avatar
slief
First make sure your spark plug wires are all seated all the way on the plugs. Also, make sure your battery cables are completely tight. That is a common root cause for the service rear axle message and it could possibly have other impacts as well including potential for misfires but that part is just speculation.
Old May 18, 2014 | 09:14 PM
6spdg37s's Avatar
6spdg37s
my c6z used to get a check engine it would disable and say service traction system. So since the code is a misfire (which sucks) it is possible that the axle and stabiltrack is related to that.
Hope the misfire is a simple fix. Keep us posted !
Old May 18, 2014 | 09:29 PM
NSC5's Avatar
NSC5
A lot (most?) GM vehicles disable the traction control system when an engine performance related DTC is active.
Old May 18, 2014 | 09:34 PM
mike13403's Avatar
mike13403
would that be for both the stabiltrack & the rear end?
Old May 18, 2014 | 09:51 PM
mike13403's Avatar
mike13403
Thanks I found 1 plug wire off Stabiltrack light went off and car sounds & runs better, still have check engine light & service rear axle!
Old May 18, 2014 | 09:54 PM
slief's Avatar
slief
Glad to help.
Next check your battery connections. That has been linked to the service rear axle message. I'd also suggest checking your diff fluid level but I am not sure what the process is on that. Regardless, I'd check those battery cables. In fact, I'd remove them completely and reconnect them several minutes later. If you have a code scanner, I try clearing it the code if the CEL persists after you disconnect the battery and reconnect the battery. Other than the above, you may need to take a trip to the dealer.
Old May 19, 2014 | 08:27 AM
6spdg37s's Avatar
6spdg37s
the check engine eventually should go out on its own after a few cycles of everything running correctly. That may take the service rear axle light off as well.
Best bet is find a local family owned shop that maybe will scan the car for you and clear the CEL for you for free. You could go to the dealer and have them do it as well, but I have people come in my boys shop and if they are nice and friendly I will scan the car for no charge/clear the light. Can you believe some people charge 100 bucks to scan a car ?
Old May 19, 2014 | 09:00 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
This may be harder than you think. I have a scan tool, and when I did my exhaust I forgot to hook up one of the front valves and it threw a light. Tried to clear the code and it told me "command rejected". Makes me wonder if you need something special to clear codes on the car..
Old May 19, 2014 | 09:50 AM
6spdg37s's Avatar
6spdg37s
Odd.... what scan tool do you have ? I have heard of some of the cheaper ones rejecting certain cars/ or visa versa the car rejecting the tool.
Old May 19, 2014 | 09:54 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Its an Actron AutoScanner Plus CP9180. Also have an SCT tuner from my mustang that can clear codes, but didnt try that one. My codes ended up clearing themselves after a few cycles.
Old May 19, 2014 | 10:05 AM
slief's Avatar
slief
Not sure about your scanner but my 2 or 3 year old Innovative Motorsports iPhone Scanner works fine for clearing codes on the C7.
Old May 19, 2014 | 11:48 AM
NSC5's Avatar
NSC5
Did you go to Actron's site and try downloading any updates for your scanner? With the changes in the exhaust system because of the additional valves to control sound in AFM mode there may be an update from Actron to handle some new DTCs.
Old May 19, 2014 | 11:51 AM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Good thought. I suppose its worth a shot to check
Old May 19, 2014 | 09:54 PM
mike13403's Avatar
mike13403
Went for a ride tonight all lights OFF just a simple plug wire thanks again
Glad to help.
Old May 20, 2014 | 02:13 AM
RKInIL's Avatar
RKInIL
Im not sure why but many have been reported popping off.
Old May 20, 2014 | 04:25 AM
Crossed Flags Fan's Avatar
Crossed Flags Fan
Probably worth it for anyone reading this post to go and give the plug wires a shove!
To Engine misfire
Old May 20, 2014 | 10:38 AM
slief's Avatar
slief
Great to hear!
Old Aug 26, 2015 | 06:42 PM
allnavyman's Avatar
allnavyman
3rd Gear
My 2014 C7 with 4088 miles on it has been to the dealer three times for the same issue with a cylinder 7 misfire code it is there know they have tried replacing plugs, coils, and ejector, code keeps coming back. Now they are waiting on GM to find out what to do next.
Old Aug 27, 2015 | 07:01 AM
allnavyman's Avatar
allnavyman
3rd Gear
Default 2014 C7 Misfire
My 2014 C7 with 4088 miles on it has been to the dealer three times for a cylinder 7 misfire code it has been there for going on four days now they have tried replacing plugs, coils, and ejector, code keeps coming back. Now they are waiting on GM to find out what to do next. Any one having this problem.
