Removable top alignment
Old May 24, 2014 | 09:27 PM
ETHYL's Avatar
ETHYL
Default Removable top alignment
I noticed that front left corner of the roof top sits level with the rubber gasket while the front right sits slightly lower which I think is the correct position. Is there an alignment correction for this. Have not gone to a dealer. Only had the car 2 days. Everything else is OK. (door gaps, very little orange peel paint). Built on April 27. Anyone have this problem corrected?
Old May 25, 2014 | 09:06 AM
air86's Avatar
air86
I don't know but do have a harder time putting this roof on compared to my c6
Old May 25, 2014 | 09:38 AM
vetehead's Avatar
vetehead
I have this on good source from factory. The proper roof position when in place at front is even with the windshield molding. My car is now 8 months old and the seal has compressed slightly in front,and because of where the roof is now (slightly lower to the windshield molding right& left) it's starting to make a knocking/ creaking sound as front handle lock position can't compensate for this so low position.
Hope this helps
Old May 25, 2014 | 10:09 AM
slief's Avatar
slief
I know you can adjust the back side of the removable top. Just not sure about the front edge.
To adjust the rear of the top, you need to remove the upper trim that spans between the B-Pillars as well as unsnapping the B-Pillar trim panels. Once you do that, there are the two pieces that the locator pins on the roof panel go into. On the face of those are two bolts. With the roof panel installed, loose those two bolts and push down on the backside of the roof until you have it to the desired position. While pushing down on it, tighten the two bolts. Do this ones side at a time. In this picture below, you can see the two bolts noted by the arrows.
Old May 25, 2014 | 10:16 AM
z51vett's Avatar
z51vett
On c5 and c6 models you could remove or pull the inside mldg. down to access the bracket held in place by two bolts loose and move down to pull top down further. May need to reindex windows if it moves much.
z51vett
Doug
Old May 25, 2014 | 10:54 AM
vetehead's Avatar
vetehead
The front is adjustable,believe it or not and this is the procedure at plant post build. The recommendation is to use a nylon block under or above the front receivers and strike with a hammer adjusting a little at at time to the front edge is even or slightly above windshield molding. I was told if I was going to remove all of the interior trim including the ISRVM at the front to be very careful loosing receiver bolts because if the adjustment goes to far out ( left or right that is) that an installation jig used at factory would be needed possible to get roof receivers in base position
To Removable top alignment
