"Performance Shift Active" Message
Old May 29, 2014 | 07:58 PM
Rossi6998's Avatar
Rossi6998
Default "Performance Shift Active" Message
I have an automatic transmission. While driving the car, I did a rapid acceleration and a message appeared on the DIC that said "Performance Shift Active."
After the message appeared, the car sounded like it was running at a high RPM before it shifted into the next gear whether increasing or decreasing speed. It reminded me of driving a stick. I was in Sport mode when this occurred.
Does anyone know what this means and the purpose behind it? I can't find anything while doing a search on the forum or google. I also can't find anything in the owners manual.
Old May 29, 2014 | 08:11 PM
onyx_z71's Avatar
onyx_z71
It is Performance Algorithm Liftfoot. It's supposed to go into that mode if you blip the throttle. Holds the gears like you would drive a manual aggressively. It goes back to normal shifting when you drive in a normal manner after so many seconds.
Old May 29, 2014 | 08:13 PM
Rossi6998's Avatar
Rossi6998
Thank you. How do you know this? Do you know where I can read more about this feature?
**Update - I found additional information on the internet. It appears they have this feature in the Cadillac. Again, thank you!
Old May 29, 2014 | 08:51 PM
bjhayes's Avatar
bjhayes
I have a 2009 Pontiac G8 GT and it has this too. If you don't know about this feature then it can be a little unnerving to have your car hanging at high RPMs and not shifting.
To "Performance Shift Active" Message
