Jack insert
Old Jun 12, 2014 | 04:48 PM
RidgebackKing's Avatar
RidgebackKing
Default Jack insert
I have the jack in the included picture and as you can tell, it's not very C7 puck friendly. The depth of the lifting "circle" is 3/4" while my pucks on the bottom of my vette are only about 1/4". I'm looking for ideas on how to either fill in the "hole" or where to get a replacement flat head so I can use the jack on my C7. Thanks!!
Old Jun 12, 2014 | 04:54 PM
-CM-'s Avatar
-CM-
It looks like that cup can be taken off.
Old Jun 12, 2014 | 04:56 PM
millpond's Avatar
millpond
Is it possible to turn the lifting circle upside down and re fasten?
Old Jun 12, 2014 | 05:00 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
My jack looks exactly like that. Take the silly round thing off and lift with the plain flat part. I do it all the time! It also lets you get under the car easier! Unscrew the bolt and sit that piece in the corner. You don't need it and it'll lift just fine.
Elmer
Old Jun 12, 2014 | 05:02 PM
kenrobb's Avatar
kenrobb
If I understand you; use a hole saw to cut out a "circle of wood to fit in the jack. Or use a larger hockey puck for the car to lift with like we did on the C6's.
Old Jun 12, 2014 | 05:11 PM
jerryv's Avatar
jerryv
Or get a piece of 3/8" plate steel cut to a size you can just lay on top of the jack ..
Old Jun 12, 2014 | 05:32 PM
RidgebackKing
I thought about seeing if I could flip the cup over or removing it altogether but the hex hole in the bolt is 3/8" wide. I don't think I've ever seen an allen wrench that big! Guess it's time to hit the hardware store and see what they have. Thanks!
Old Jun 12, 2014 | 05:41 PM
Zymurgy's Avatar
Zymurgy
Moderator
A flat bladed screwdriver might work instead of the large allen wrench.
Old Jun 12, 2014 | 05:43 PM
Zymurgy's Avatar
Zymurgy
Moderator
How deep is the cup? The Elite Engineering aluminum pucks are almost 1" thick and have no problem clearing the cup on my jack.
Old Jun 12, 2014 | 06:06 PM
Vetinvett's Avatar
Vetinvett
Put a hockey puck in it.
Old Jun 12, 2014 | 06:20 PM
bimmerborn's Avatar
bimmerborn
The Saddle (cup) comes off with an Allen wrench.
http://manuals.harborfreight.com/man...9999/69227.pdf
Old Jun 12, 2014 | 06:41 PM
eboggs_jkvl
Moderator emeritus
Take the damn cup off. The jack will do fine without it!
Old Jun 12, 2014 | 06:42 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
My exact thought too
Old Jun 12, 2014 | 07:17 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Throw a block of wood in the jack and be done. The truth is, leave in jacking pucks only work best on lifts, not jacks.
Old Jun 12, 2014 | 07:29 PM
TEXHAWK0's Avatar
TEXHAWK0
Putting the puck on the jack without the cradle will work, but if you lift the car on just one side, be careful it does not slide off the jack. This happened to a friend and it ruined the rocker panel.
My jack has a rubber cover for the cradle, and I have never had it slip.
It might be safer just to invest in thicker jacking pucks.
Old Jun 13, 2014 | 05:08 AM
robertbruce's Avatar
robertbruce
[/QUOTE]
I bought the aluminum one from Harbor Freight for $59.00. It is flat with rubber padding.
Old Jun 13, 2014 | 07:02 AM
C7Joy's Avatar
C7Joy
I have done this myself. I have the plastic, permanent jacking picks installed so I have 4 rubber pucks from my C6 to work with.
To Jack insert
Old Jun 14, 2014 | 08:39 AM
RidgebackKing
I found I had a 3/8" hex socket and was able to take the cup off the jack and just use the flat surface. Thanks!
P.S. I'm thinking of spraying the flat part of the jack with some of that stuff used to line truck beds for anti-slip properties. Think that would be beneficial?
Old Jun 14, 2014 | 09:00 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
I bought the aluminum one from Harbor Freight for $59.00. It is flat with rubber padding.[/QUOTE]
Agree the rubber pad helps. I also use 2 Harbor Freight low profile aluminum jacks with roller front wheel and caster rear wheels. I used jack pads that fit in the shipping slots. Still must be sure the rear caster wheels are facing properly so as you lift the Jack moves in since the pad does move front to back somewhat as it’s lifted. Also the surface must allow in to move in.
Old Jun 16, 2014 | 05:11 PM
Highway 61's Avatar
Highway 61
From: Between Forest Lake and White Bear Lake in the Land of 10,000+ lakes
I would put the cup back on and buy a $3 hockey puck to place in it. Works on both the front and rear sides of the car. Before you lift the jack up, just make sure the puck is clear of the body panel. I have the same type jack and works great.
