Catch can
Old Jun 13, 2014 | 08:25 AM
v8capt's Avatar
v8capt
Default Catch can
Is a catch can really needed on a 2014 C7 base car . If installed could it void your warrantee?
Old Jun 13, 2014 | 08:58 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Lots of Posts on the issue, see this thread:
http://forums.corvetteforum.com/c7-g...all+Catch+Info
In my opinion, may depend on how you drive the car. With Direct Injection both the base car and Z51 have a PCV system they causes crankcase blow-by etc to pass through the intake and hot intake valves without the benifit of gasoline as in the prior port injection helping to clean the back of the valves! Installing a catch can can help!
Old Jun 13, 2014 | 09:08 AM
sdcnews's Avatar
sdcnews
Default Any oil in CC
For those of you who have installed catch cans. Are you getting any oil in the can???
Old Jun 13, 2014 | 09:13 AM
Glen e's Avatar
Glen e
Base car: 2/3 tablespoon per 1000 miles...all city driving..
Is it NECESSARY?
Not in my opin ...but if you are an enthusiast , it's an easy install to keep your engine cleaner....
Old Jun 13, 2014 | 10:38 AM
Zymurgy's Avatar
Zymurgy
Moderator
I'll repeat what I posted in your other thread on this same subject (Catch can for base car):
Personally, I'm convinced that most of the problems we are seeing (such as the photo above and others) is due to overfill on the Z51. The owners manual has an incorrect value for the Z51 oil capacity (there is an insert with the correct value) and there is a very specific process to follow to measure the oil level. If you don't follow the instructions, it is easy to overfill. This may have been done during PDI or at first oil change or even by the owner.
I have checked the oil level in my Z51 and it is spot on. I have also removed the air intake when I installed my Airaid air filter and it was spotless - no hint of oil.
Still, I plan to install a catch can and the clean oil separator. I think of it as an insurance policy to keep the MAF from getting fouled by oil should the OEM PCV valve get stuck (this has been reported already).
This is solely my recommendation and everyone can feel free to either support me or disagree with me:
Non Z51 - Elite's "Good" or equivalent
Z51 - Elite's "Better" or equivalent
Either with turbo added - Elite's "Best" or equivalent
In the previous thread, several members agreed with my recommendation, none disagreed.
To Catch can
