Operating temp
Old Jul 12, 2014 | 02:34 PM
dckotwicki's Avatar
dckotwicki
Default Operating temp
Picked up a C7 this week and I am noticing the engine operating temp at out 220 degrees. This is about 20 deg warmer than my C6.
Is this normal?
Does I cool down after break in?
Old Jul 12, 2014 | 02:38 PM
Glenmcp's Avatar
Glenmcp
Mine has been at 220 the entire time I have had it. 4,500 miles and 9 months.
Old Jul 12, 2014 | 02:50 PM
ta70raiii's Avatar
ta70raiii
CI 6-7-8-9 Veteran
Sounds right to me...nothing to worry about.
Old Jul 12, 2014 | 02:56 PM
Larry/car's Avatar
Larry/car
Normal for the C7. Don't stress!
Old Jul 12, 2014 | 02:58 PM
lastcowboy's Avatar
lastcowboy
abut 110 60% hum. runs 208-220
Old Jul 12, 2014 | 04:37 PM
RussM05's Avatar
RussM05
Do a search on this. There are a few other threads that cover this subject thoroughly.
Old Jul 14, 2014 | 10:10 AM
wgood's Avatar
wgood
Is this normal?
No difference between 35 degrees and 95 degrees outside other than at 95 the fans came on and op temperature still 220 !!! Wayne
Old Jul 14, 2014 | 11:12 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Cliff notes: The mechanical temp gauge is NOT showing 220. It's showing around 205. The 220 marking on the gauge face is very misleading.
If I really want to know the correct temp, I use the gauge in Perf. And my C7 (Z51, M7) has never gone above 212 and that was in 95+ outside temps and under load. At idle, even in hot outside temps, it never goes above 205.
Old Jul 15, 2014 | 07:35 AM
beepster's Avatar
beepster
I use the same guage, but you need to add an addt'l 5-7 deg for those of us in the "hot country".....
To Operating temp
