C7 oddities
Old Aug 17, 2014 | 06:42 AM
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
Originally Posted by vettetwo
Put your A6 in M mode. It will remain in V8 all of the time. Of course, you must do the shifting. But if you are cruising at a constant speed and not changing gears, it will remain in V8.
Way to much work. The problem is with sound of an aftermarket exhaust system in conjunction with four cylinder mode. To go to that much trouble you might as well buy a standard shift. In my opinion of course.
Old Aug 17, 2014 | 07:37 AM
Cruiter's Avatar
Cruiter
On order: Torch Red Z51
That's true, I use it that way often when out of the city.
