Cluster does not change
Old Aug 7, 2014 | 11:15 PM
hankman's Avatar
hankman
Default Cluster does not change
I am trying to change the cluster display to the performance one with the half moon tack....track mode tack cluster display. I put the selector in track mode, Tr nothing changes . How do i switch to the performance
cluster screen ? thanks
Old Aug 7, 2014 | 11:18 PM
Glen e's Avatar
Glen e
Settings on right steering wheel button yoke
Link to,drive mode
Old Aug 7, 2014 | 11:19 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
move to the settings menu on the left, then go back to center screen and scroll up or down till you see drive mode now move to the right and you will see a setting for "link to drive mode"
Old Aug 7, 2014 | 11:20 PM
aj98's Avatar
aj98
Right side steering wheel buttons, go to setting, change the cluster to track. If you want that display full time Do not select link to driving mode.
That should do it
Old Aug 8, 2014 | 12:30 AM
hankman's Avatar
hankman
engine have to be on , or just the acc to on....thanks i will try again
Old Aug 8, 2014 | 12:49 AM
hankman's Avatar
hankman
I did it now i lost my trans temp and oil pres,,,,i will play with it more tomorrow... thanks guys
Old Aug 8, 2014 | 08:33 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I posted a thread about this several months ago. It is in the sticky thread for Manuals and Reference Materials.
http://forums.corvetteforum.com/c7-g...cking-etc.html
I thought it best to cross post it here since people may not find the sticky post.
When the Stingray shipped it was originally intended for the IP gauge cluster to be "Linked to the Driver Mode". Turns out, this is not the case and I'm getting lots of requests to help folks understand what is going on as well as seeing some folks ready to head back to the dealership because they think there is something wrong with their car. If you haven't found it yet, and you would like your IP gauge display to change modes when you move your Driver Mode Selector ****, you will need to do the following.
Using the four way switch on your right steering wheel spoke, press the left arrow and it will bring up your configuration menu. It should look something like the left photo in this image.
From the Sport or Tour Driver Mode (S or T displayed under the Tach).
Using the down arrow, scroll to the bottom of the list and select the "Settings" menu using the SEL button at the center of the four way switch.
Now, using the four way switch again, press the up and down arrow until the center display shows Display theme as pictured here:
Now, using the four way switch again, press the right arrow and you should see this display as pictured here:
Using the four way switch, use the up arrow to highlight "Link to Driver Mode" and press the SEL button.
This will set your display on the IP to change when you move the Driver Mode Selection ****.
Old Aug 8, 2014 | 12:04 PM
hankman's Avatar
hankman
thanks....big help seeing pics.....GM should pay you........
Old Aug 8, 2014 | 12:10 PM
-CM-'s Avatar
-CM-
Note that the car must be on in order to change vehicle settings. You can turn the car on without starting the engine by pressing and holding the start button without depressing the brake/clutch. You have to hold it for several seconds, just be patient.
Old Aug 8, 2014 | 12:23 PM
talon90's Avatar
talon90
NCM Ambassador
Ignition on/Engine off mode. 10 seconds.
To Cluster does not change
