Dealer Prep
Old Sep 3, 2014 | 01:17 PM
Al Engel's Avatar
Al Engel
Default Dealer Prep
Anybody have access to post the Pre-delivery process Chevrolet instructs dealers to perform for the C7?
Old Sep 3, 2014 | 01:28 PM
Woody's Avatar
Woody
CI 2-3-4-5-6-7-9-11 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'12-'13-'14-'15-'16
First St Jude Donor '14-'15-'16
NCM Lifetime Member
I doubt it changed much this year.
File Type: pdf
Old Sep 3, 2014 | 02:16 PM
Glen e's Avatar
Glen e
good stuff...thank you for adding content here.....
Old Sep 3, 2014 | 02:40 PM
rramjet's Avatar
rramjet
Thanks. Great info especially since I'm getting a Courtesy delivery to a dealer I've never even been to at our Winter location.
Old Sep 3, 2014 | 02:51 PM
Thanks for that info.
Old Sep 3, 2014 | 03:13 PM
theanswriz42's Avatar
theanswriz42
Cruise-In 8 & 10 Veteran
St. Jude Donor '08, '15
I wonder if you can get a copy of the completed form from the dealer when you take delivery.
Old Sep 3, 2014 | 03:18 PM
Glen e's Avatar
Glen e
Not only CAN you get a copy, you SHOULD get a copy per GM procedures...see bottom of page 2 of the above PDF ....
Old Sep 3, 2014 | 03:26 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It should end up in your folder of completed paperwork from the dealership.
Old Sep 3, 2014 | 03:27 PM
laborsmith's Avatar
laborsmith
In my experience, I had to ask. Just like the Order Workbench, some dealers will give you a copy while some will say that is not allowed.
Laborsmith
Old Sep 3, 2014 | 03:35 PM
theanswriz42
sweet
Old Sep 3, 2014 | 03:48 PM
doug doo wop's Avatar
doug doo wop
I didn't read everyword of the form, but I didn't see anything about checking all fluid levels. There have been cases that transmission fluid was low and other levels also.
Old Sep 3, 2014 | 03:55 PM
hdwideglide's Avatar
hdwideglide
Old Sep 3, 2014 | 03:56 PM
talon90's Avatar
talon90
NCM Ambassador
Checking and fill as required engine fluid levels is listed in the underhood section.
Additionally, there is a TSB with dealer service departments to check eLSD fluid level.
Old Sep 3, 2014 | 04:01 PM
EvoX2008's Avatar
EvoX2008
First page, first column, last item (under "under hood" section).
Old Sep 3, 2014 | 04:22 PM
bbrown450's Avatar
bbrown450
what form...? never saw that or received it ....shocker
Old Sep 3, 2014 | 07:02 PM
ckwhite's Avatar
ckwhite
I'm assuming the same things are done if you request a Museum Delivery (?) Somebody mentioned that they will also mount your splash guards, but that you have to order them yourself and then ship them to the Museum. Why can't I just order them when I order the vehicle?
Old Sep 3, 2014 | 07:28 PM
Asterism's Avatar
Asterism
for whatever reason they are dealer installed options, not factory installed options.
you can pay the $25 at the museum and they will do the install as
part of the PDI if you ship them there first.
To Dealer Prep
Old Sep 3, 2014 | 07:57 PM
C7Joy's Avatar
C7Joy
I'll have to check my paper pile from delivery. I don't remember seeing that one. It is pretty extensive.
Old Sep 3, 2014 | 08:17 PM
laborsmith's Avatar
laborsmith
If you are referring to the PDI, unless you specifically asked for it you did not get it. And it is extensive AND I have been told the dealer is paid to do it and the form needs to be in the jacket in case the deal us audited.
$150 a few years ago, do not know if changed in recent years.
Laborsmith
Old Sep 4, 2014 | 07:17 AM
Al Engel's Avatar
Al Engel
Woody: Thanks - exactly waht I was looking for.
Save the wave!
Al
