2014 potential fuel leak issue
On the other hand, I do think your house burning down as would be the likely result if the car in the garage burned down is pretty damned serious, insurance or not. Don
I spoke with the mechanic directly. He said the one he is working on is the 4th one he knows about, not the 4th one he's worked on.
The fuel tanks are injection molded plastic. A seam on the top starts to separate, and dumps about 1/2 gallon on the floor.
The VIN of the one he is working ends in E5111110
PITA is right. More so for GM. These parts are outsourced. BG just assembles. GM did proper by doing a 10-year free service on it case by case basis.
LR tire, the LR wheelwell liner, and several other parts I didn't recognize were also off and set aside.
https://www.corvetteforum.com/g/picture/1265064
The C5 problem was isolated to a range of VIN's built in late 2003 ( 04 model year C5's).
Sorry about your problem, but it almost certainly is one of many very isolated, almost one-off, assembly-line problems, which are seen in all brands. It has not proven to be a trend or anything more than a freak event.
Reminds me of when I had something done on my wife's car some years ago at a Foreign car shop in town, no longer in business. Brought it home and found a pin hole leak in the power steering hose. Fluid was coming out in a fine stream in the center of the hose. Expensive repair, by them as I had no other shop to bring it! Always was suspicious they did it!
If it is a sender that is an issue, a poster said his dealer solved that with two containers of the GM fuel additive listed in the Owner's Manual. Charged him $100.
The problem with sulfur build-up on seniors is well known. Techron and the GM "stuff" (probably Techron with their name and 3 times the price as the SDS sheets are the same!) say they clean sulfur from senders.
This has nothing to do with Top Tier gas, etc. All crude oil contains sulfur. Some several percent. Some gets removed in refining but not all. Added the GM "stuff" in my 3 1/2 year old C7 every oil change per the Owner's Manual, as a precaution. Will use the cheaper Techron in the Grand Sport.
Special Coverage Adjustment
16009 Primary Tank Inlet Check Valve Fuel and Vapor Leaks
Details here:
http://www.corvetteactioncenter.com/...eaks-1312.html
Of course, there can be other issues, but this is one is acknowledged by Chevy.
Ron
The fuel inlet attaches to a rubber hose, which then goes to the fuel tank.
She was careful filling it up thinking she may have overfilled or spilled some gas getting the nozzle out of the fill pipe at the station. Still a gas smell in the garage.
She made an appointment at the dealership and they checked it out. Cracked gas tank. They kept the car for 2 days. Had to order the tank and take a lot of stuff off the car to replace it.
It was covered under warranty and didn't cost us anything except the inconvenience. There was approx. 45,000 miles on the car when this happened.
Took the car into the dealer for the extended warranty for fuel pump flange issue, they said it was covered.
After 2 weeks I called the dealer and they said the parts have just arrived and the car would be ready tomorrow.
Then I got a text message that the filler tube where it attaches to the tank was cracked and they needed a payment for $1500.00 for a new tank.
I went several rounds with them and got no where. I asked for the GM Corp phone number and they refused to supply me the number.
I found the number on the WEB and they so far have not step up to the plate to resolve this issue, So much for customer satisfaction.
Also I went to a non dealer Corvette Repair Shop and the owner said the fuel tank parts always fail, he showed me several fuel tank fail parts.
... Four cracked tanks, all at the same dealer
