Wind noise
Old Sep 17, 2014 | 04:48 PM
mike wisdom's Avatar
mike wisdom
Originally Posted by Gazi
Off topic but what is Block-It
It is a sound deading mat that lays in the rear compartment
Old Sep 17, 2014 | 04:49 PM
mike wisdom
Originally Posted by SCorvette08
Mike I right now as we speak am going through warranty for the wind noise what they found out is it is the roof and the faster you go the more it opens the gasket and you hear it I thought i was hearing it from the windshield but it was the roof warped and the front edge dosnt seal the
gasket here is what to try as you drive pull hard down on the lever that locks your front driver roof handle and see if it subsides
Will try, Thanks
Old Sep 17, 2014 | 04:51 PM
mike wisdom
Originally Posted by z51vett
I wear hearing aids and I just open up the exhaust drowns it all out.
z51vett
Doug
Lol maybe by the time I need a hearing aid I wont hear it
I knew I should have ordered the npp but since it will be going to Lingenfelter soon I wont hear it anymore
Old Sep 17, 2014 | 04:56 PM
garyo's Avatar
garyo
I have the same noise in the same place in my 2015. I will be subscribing to this thread to see what transpires.
Old Sep 17, 2014 | 05:02 PM
mjw930's Avatar
mjw930
I have it too and I'm pretty sure it's caused by the angle of the union of the door glass and the top at the rear of the window. Air isn't leaking through the window seal, its being packed into the corner. If the door glass was further out it would be an issue but that's not possible due to the way the roof attaches.
I seriously doubt it can be corrected and is simply the nature of the beast.
If someone wanted to test this theory they could fabricate a deflector that could mount in that area and prevent air from packing into that corner.
Old Sep 17, 2014 | 08:28 PM
mike wisdom
I think you have it nailed down
Mike
Old Sep 17, 2014 | 11:31 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Originally Posted by mike wisdom
Thanks William It is not severe and I will bring it up with my dealer next time I am in for service to see if it is any real issue
You're very welcome,
Don't hesitate to keep me posted. As always, feel free to contact us by private message if you have any other concerns.
William R.
Chevrolet Customer Care
Old Oct 20, 2014 | 11:26 AM
C7 Mojo's Avatar
C7 Mojo
3rd Gear
The dealer agreed that the noise was abnormal and had their body shop "realign" the driver door (whatever that means). The wind noise is now much diminished and only seems to be coming from the outside, where before it sounded like it was leaking through to the inside around the door and window seals. As a side-effect, the drivers door now requires a little more force to close (but not too much).
Old Oct 20, 2014 | 11:51 AM
NavyBlue2's Avatar
NavyBlue2
I love the tons of wind noise, til my wife tells me to put the convertible top back up...
Old Oct 20, 2014 | 12:20 PM
Algiers's Avatar
Algiers
Will they have to replace your roof to fix it?
Old Oct 20, 2014 | 01:06 PM
bontrager's Avatar
bontrager
It's sound deadening material that's sold in sheets and can be used under the carper in the hatch and under the carpet in front and behind your seats.
Old Oct 20, 2014 | 01:41 PM
C7Joy's Avatar
C7Joy
I have not noticed the wind noise on mine. Now that the weather has turned colder I am running roof on, windows up, pretty quiet in there.
Old Oct 20, 2014 | 08:11 PM
  #33
mike wisdom
Thanks for the info I will relay this to my dealer when I take it in.
Old May 22, 2016 | 10:09 AM
  #34
wapnbp's Avatar
wapnbp
Cruising
Default 2016 coupe wind noise
Originally Posted by Chevy Cust Svc
mike wisdom,
I understand the displeasure when dealing with wind noise concerns. While I realize you're seeking opinions from others, if you feel an official GM diagnosis is necessary, I'd be happy to communicate your sentiments with the Customer Experience Managers (CEM) at your preferred GM dealer. Please know that you're welcome to message us privately if you'd like to proceed, or if you simply want your experience(s) officially documented.
William R.
William
I just got a new 2016 C7 coupe with carbon fiber roof panel and am surprised with the amount of wind noise that I get from the rear space of the cockpit at speeds at or greater than 50mph. The roof panel seems to fit fine with no rattles or squeaks. I will check with a decible meter but i'm guessing close to 80 dbs. Is this normal?
Old May 22, 2016 | 10:30 AM
  #35
OVR60's Avatar
OVR60
William R.
Come on Customer Care you know what the problem is after 3 years of production and GM can fix it if they wanted to.
Old Apr 3, 2017 | 09:27 AM
  #36
SteveBoss's Avatar
SteveBoss
2nd Gear
Default 2017 Z06 coupe wind noise issue
I just picked up my car and drove it 3 miles turned around and went back to the dealer. There is a wind noise or more like a rush/hush of air in the interior. It is in the back cavity and starts at around 50MPH. It is not road noise. The dealer said that is normal I say BS. I am about to start to use some tape and tape off the rear hatch and see if that improves the sound level. This is not worthy of a car that runs you in excess of $110K.
Yes the dealer has the money and I have a car I am not happy with.
Old Apr 3, 2017 | 11:43 AM
  #37
wapnbp's Avatar
wapnbp
Cruising
Default C7 wind noise
After 3000 miles and adding a sound barrier mat behind the seats, I believe that the noise is from the road and not wind. When I drive on new blacktop, the road noise reduction is remarkable.
And, this is a much bigger problem with coupes than with roadsters. The body panel behind the seats in a convertable block much of the tire noise.
There is little to no insulation under the carpet of a coupe and the shape of the "trunk" is like a megaphone blasting road noise to the occupants.
Can any member who has installed sound barrier insulation under the carpet provide us with feedback on how much this has helped?
To Wind noise
Old Apr 3, 2017 | 12:27 PM
  #38
toph1206's Avatar
toph1206
I have this same problem. When I took it to the dealer he contacted corporate for a fix. Their response was to basically stuff in foam. GM knows of this issue but apparently has not come up with a elegant fix. My tech said I am not stuffing foam into a 70K car. GM needs to actually fix the issue.
Old Apr 3, 2017 | 02:17 PM
  #39
SteveBoss's Avatar
SteveBoss
2nd Gear
Thanks guys, I will pull the carpet and install some DynaMat and see if this helps. I never drove the car before buying it so it is my problem now. I am sure I would have noticed this in a test drive.
Old Apr 4, 2017 | 01:20 AM
  #40
Scottcolem's Avatar
Scottcolem
I went on a road trip this past week and noticed wind noise the faster I went, the louder the noise. it definitely sounds like its coming from the roof area.
