Problem with car scraping?
My C6 scraped many times during the day I have yet to hear the new car scrape.
You will be fine, buy with confidence.
But to the OP, you just have to be careful.
I made a thing out of wood to check the speed bumps in places I normally drive. It was a straight piece of wood the length of the C7 wheelbase with an upright on each end set at the clearance I measured under a C7 on a dealer's showroom. I found several places I wouldn't be able to drive a C7 without scraping the bottom of the car.
I can't speak for the C7 as I have a C5 (lowered about 1.5") but...
Learning HOW to negotiate steep drives, intersections and speed-bumps makes all the difference in the world.
Just be sure to approach them at an angle. For example, if you're trying to turn onto a steep drive that is perpendicular to the road you're on:
Stay as close to perpendicular to the drive as you can until your front tire makes the transition, then you can turn into the drive so you're parallel to it. this will negate the overhang of the nose almost completely. Kind of hard to explain in words...
This video shows the proper technique, even though his car is so low it still scrapes, and you can even take it at more of an angle than he did.
Also here is a thread, where someone else explains with pictures:
http://www.ft86club.com/forums/showthread.php?t=22507
In short, if you approach at an angle, you will cause your front tire to hit before the nose of the car. This works for speed bumps too. If you're having trouble with the MIDDLE of the car dragging on "crests" (tall speed bumps too), just try to make sure the car is at an angle when the center goes over. This way your front tire on one side will be on the crest at the same time as your rear tire on the other side.
Once you learn how to do it, you can mitigate almost all "rubs". Having said that, it sounds like a factory C7 has plenty of clearance for most drives and speed bumps.
Don't let something like that detour you from getting a Vette. It's not that big of a deal whatsoever. Promise.
One poster above says his cars height is at factory settings. That means nothing. Look at any number of C7s...... see any factory cars at the same height? They are all over the place.
One thing you can do is actually raise the car...just the opposite process of lowering it assuming you have some room on the bolts.
In my case my C5 and C6 GS scrapped the bottom of my driveway unless I angled and backed in. Neither where ever lowered or ever adjusted. I've dropped the C7 all the way on the stock bolts and I have more clearance then either of the previous models. I think you will be fine.
However dirt roads have ruts. Wet, dirt, ruts the road can change daily.
Enjoy your car.
