Winter Storage
Old Oct 10, 2014 | 09:52 PM
Stan Dinoff's Avatar
Stan Dinoff
2nd Gear
Default Winter Storage
First time storing my 2014 Vette for 6 months, any suggestions i.e. oil change, best trickle charger,fuel additive, tire pressure
Old Oct 10, 2014 | 10:16 PM
wayles's Avatar
wayles
There was a thread back in September dealing with this subject. It was a pretty thorough list of things to do. I don't know how to link a thread in my response, but I copied and pasted the link below.
If it doesn't work. just search in the C7 general discussion section and you should be able to find it.
https://www.corvetteforum.com/forums...winter+storage
Old Oct 10, 2014 | 10:20 PM
pgj98m3's Avatar
pgj98m3
The best solution is to move to Vancouver....maybe 7 snow days total!!
Old Oct 10, 2014 | 10:27 PM
-CM-'s Avatar
-CM-
There are countless threads on this topic with every kind of technique suggested. Use the search function, and note that there is nothing specific to the C7.
I do not store mine in the winter.
Old Oct 11, 2014 | 01:24 AM
oyealiz's Avatar
oyealiz
2022 C8 of the Year Finalist - Unmodified
CI 3-4-5-6-7-8-9-10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'16
I live in Dallas. We don't even close the pool in the winter.
Old Oct 11, 2014 | 06:34 AM
Glen e's Avatar
Glen e
But you get some wicked ice storms, lived in plano for 5 years....
Old Oct 11, 2014 | 08:01 AM
LIStingray's Avatar
LIStingray
Just sell it and buy a new one in the spring
Old Oct 11, 2014 | 09:44 AM
C7Joy's Avatar
C7Joy
Oil change if not done recently, clean inside and out, full fuel tank, battery tender, cover for the long winter's nap.
Old Oct 11, 2014 | 11:06 AM
Snowwolfe's Avatar
Snowwolfe
Wash wax and get a nice thick cover for it. If you want to use a battery tender, fine. If you don't, just disconnect the negative terminal.
Adding fuel stabilizer is a total waste as no one can show proof that it actually works.
I lived in Alaska for over 35 years where all the big toys stayed in storage for about 7 months each year and never used battery tricklers or stabilizer and had zero issues with any vehicle we owned.
Old Oct 11, 2014 | 11:27 AM
dvilin's Avatar
dvilin
Full tank of gas, no additive necessary, beltran battery tender plus, pump tires up to 35lbs, oil change if you want to also not really necessary, cover it and hope it is a quick Winter.
Been doing this for 6 years and never had any issues.
Old Oct 11, 2014 | 11:37 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
This.
Old Oct 11, 2014 | 11:56 AM
Larry/car's Avatar
Larry/car
Shut down car at normal operating temperatures after a decent drive, push the start/stop button until next time. Battery tender if anticipate car sitting three weeks or more.
Old Oct 11, 2014 | 12:29 PM
NTMD8R's Avatar
NTMD8R
And if you want/need a good new car cover.....
https://www.corvetteforum.com/forums...9155506-a.html
Old Oct 11, 2014 | 04:41 PM
oyealiz's Avatar
oyealiz
True, but usually only one-two a year or even one every 2 yrs. I'll take that over storing my vettes for months at a time!
Boy when we do get those storms, it's totally crippling, though! As you'd know since you lived here.
Old Oct 11, 2014 | 05:46 PM
wayles's Avatar
wayles
Was through there a number of years ago on an Alaskan cruise. Beautiful area. I was amazed at how moderate your climate is.
Old Oct 11, 2014 | 08:05 PM
robert68's Avatar
robert68
4th Gear
Have a 2006 corvette am storing for winter, if I disconnect the battery, how,do i open the car doors without any power ? Bob!
Old Oct 11, 2014 | 08:09 PM
TKay's Avatar
TKay
I live in Northern IL, and the winters here can be a real pain. While I do not drive it a lot, I take it out on days when there is no chance of snow or anything. I figure if I can get it out every few weeks, storing it is not necessary. Never had a problem doing this.
Old Oct 11, 2014 | 09:18 PM
Larry/car's Avatar
Larry/car
Use the key in the key slot above the license plate, open the hatch and pull the door cable.
Old Oct 11, 2014 | 09:33 PM
TBIRD57's Avatar
TBIRD57
Default stay positive..
you can eke out a few more weeks yet. maybe it will be a short warmer
winter.
To Winter Storage
