Mode select switch fixed ????
Old Oct 16, 2014 | 08:43 AM
repo czar's Avatar
repo czar
Originally Posted by Tommy D
It does not happen often to mine but when it does no matter how you turn the **** it will only go to weather or track. Please let me know what they found as my dealer could not duplicate the problem.
It was a failure. They said there were no updates to fix my problem. I got my Stingray back last night and it continues to malfunction regularly.
Old Oct 16, 2014 | 08:56 AM
rdrnr's Avatar
rdrnr
My mode selector switches perfectly. It is important to give the dial a solid twist and release.
Old Oct 16, 2014 | 09:30 AM
*C7*'s Avatar
*C7*
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
On the ones that have this issue it does not matter how you twist it,
it just flat does not work properly and GM should fix it.
Old Oct 16, 2014 | 04:28 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by CaryBob
Exactly my experience. Turn the **** and release... Turn the **** and release... repeat as necessary. Works every time.
I had it happen, but it was because I failed to wait after the release. Sometimes the dash doesn't change right away. Because of this... I jumped-the-gun once; thinking I hadn't moved the wheel fully, so I turned it again.. and it skipped twice.
Since then, I have operated the wheel and waited. So far, it's been fine; but keeping an informed eye on it.
Old Oct 16, 2014 | 09:23 PM
cb98coupe's Avatar
cb98coupe
Twist hard and release , just like others have said . It's really simple . Why do people freak out about this stuff . Just learn how to use it .....
Old Oct 16, 2014 | 09:37 PM
*C7*'s Avatar
*C7*
With all due respect it is not a question of learning how to use it. Yours may work just fine but many of us have ones that do not work worth a dang.
How do you explain turning the **** and the display moves in the wrong direction ????
It is NOT operator error. 90% of the time it works OK. 10% of the time it moves in the opposite direction or does not move at all.
Old Oct 16, 2014 | 09:51 PM
aforand's Avatar
aforand
Mine acts the same way as Tommy D! Not fun!
Old Oct 17, 2014 | 09:32 AM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Yes it seems some of our members think that we do not know how things work in the C7. This is not the case. The C7 has electrical/computer issues.
1.) Radio does not always find other media (I pod, usb stick etc)
2.) Mode selector switch does not switch modes correctly
3.) Sound management once turned off can not be turned back on
4.) Hesitation on hard acceleration (either trans or engine)
Unfortunately, the aforementioned do not happen on a regular basis, sometimes the car is fine.
When we complain to GM customer service we get no help and the dealers tell us the problem can not be duplicated or that is how it works.
It is very clear to me that GM has no intention of addressing our concerns.
Thank you Repo Czar quick for the response
Old Oct 17, 2014 | 12:04 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Does this mean there is no fix for this? That at least some out of all users have a sometimes/much of time/all the time malfunctioning mode selector switch?
Old Oct 17, 2014 | 04:17 PM
BigJoe's Avatar
BigJoe
One selection change at a time. Hasn't acted up since the first week before I knew about the twist release method. Since I only use Sport and Turing it's no big deal for me since I'm only going one slot anyway.
