Starting and Operating
New Vehicle Break-In
Follow these recommended
guidelines during the first 2414 km
(1500 mi) of driving this vehicle.
Parts have a break-in period and
performance will be better in the
long run.
For the first 322 km (200 mi):
. To break in new tires, drive at
moderate speeds and avoid hard
cornering for the first 322 km
(200 mi).
. New brake linings also need a
break- in period. Avoid making
hard stops during the first
322 km (200 mi). This is
recommended every time brake
linings are replaced.
For the first 800 km (500 mi):
. Avoid full throttle starts and
abrupt stops.
. Do not exceed 4000 rpm.
. Avoid driving at any one
constant speed, fast or slow,
including the use of cruise
control.
. Avoid downshifting to brake or
slow the vehicle when the
engine speed will exceed
4000 rpm.
. Do not let the engine labor.
Never lug the engine. With a
manual transmission, shift to the
next lower gear. This rule
applies at all times, not just
during the break-in period.
For the first 2414 km (1500 mi):
. Do not participate in track
events, sport driving schools,
or similar activities during the
first 2414 km (1500 mi).
. Check engine oil with every
refueling and add if necessary.
Oil and fuel consumption may be
higher than normal during the
VetJazz' post covers it all, no matter where you take delivery. Vary those speeds on the interstate, and don't use cruise. Maybe vary the gears too, just don't exceed 4k RPM.
Set the cruise all you want, its not about speed, go up and down the top three gears every 10 min each and youll be fine. Someone will come along here and say its the other running gear componrnts that need the speed change, my opin is that is true , but happens normally enuf in driving to not worry about that. Its pretty much all about seating the rings.
Then again, i know automotive engineers that will tell you that on todays engines, unless you drag race them right off the lot, no break in is really necessary.
My car used some oil, 1/2 quart first 1,200 miles, has stabilized and at 1,900 miles no additional oil was used. (base car, M7) Don't forget to check your oil level at delivery so you have a base line to track oil use from.
When I picked mine up in Aug in Missouri, the salesman said only to keep it below 3500 RPM the first 500 miles and to row through the top 3 gears periodically. In fact he pointed out(and it was true) that there was a temporary "red line" at the 3500 RPM mark and I saw it disappear as soon as I hit 500 miles. I never used the cruise but the roads were great and the weather perfect for the 800 mile trip home. I really have had no perceived oil loss I can determine. I'm easy on brakes anyway and the trip home was all interstate.
My A6, at 2000 rpm, cruises at 95 mph. I drove the 1,800 miles home from the museum over 3 days, no cruise, 1,500-1,800 rpm, no problem. I clicked off the 500 mile mark the first day, and the 1,500 mile mark the 3rd. Currently 6,500 miles with no issues.
Vary the RPMs and the gears, don't accelerate or brake suddenly (unless you are avoiding a deer or a child, or a dear child), and you will be just fine. Check the oil at every fuel stop.
What they told me is to not put the car in Cruise control for the first 500 miles. Try to go up and down in speed, accelerate and decelerate and repeat. Try to use different gears - DO NOT use Eco (V-4) mode at all. Don't keep it at one constant RPM.
Aside from that, as soon as the yellow break in period bar disappears, you can use it as normal.
I did and I didn't see any problems.
What I would say is the clutch takes a long to to properly break in. It's really touchy and very sensitive at first.
My C7 is a 7 speed manual- I asked my salesman, a dedicated Vette guy about break in when I picked it up a few weeks ago, and I was told to drive it normally, no break in (I guess since its a manual)
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Your salesman is ignorant. FOLLOW THE BREAK IN INSTRUCTIONS IN YOUR OWNERS MANUAL. And it is more than just about the engine
Cliff notes: For the 1st 500 miles, vary speed, change gears, don't exceed 4000 revs and no WOT. Don't stomp on the brakes either
(200 mi).
abrupt stops
control.
4000 rpm.
You should listen to the engineers that designed your car, not a salesman.
I trusted the engineers that made my C7's engine so I basically went by the owners manual.
You will get many options here.
I did the same thing and it makes sense. It takes time for the rings, rocker arms, lifters etc. to wear the slight high spots and lap in! Also the trans and rear end gears. I drove home and used 4th gear and all three overdrives (5th, 6th and 7th) to vary the engine speed. Fun to do.
We just bought a BMW SUV and it limits the I6 to 4500 rpm for 1200 miles. Then it says gradually increase until you reach the 7000 rpm red line. Pretty sophisticated DI engine (double over head cams, 4 valves per cylinder and twin turbos -300 hp for 3 liters. That would be equivalent to 620 hp if 6.2 liters) and no doubt it has been machined to very tight tolerances.
