Question about center console lid
Old Oct 26, 2014 | 04:03 PM
Beezvette's Avatar
Beezvette
Default Question about center console lid
I seem to have two finger indentations on the top of my console lid, I suspect from my other half pushing down when she gets in or out. I can see that the lid is removable, but is the leather glued to the top? If i can get the leather off I can fix the foam below. Any suggestions?
I tried a cloth with hot water and it did not help.
Thanks!
FWIW: i removed the console, removed the top, and hit it with some heat from the iron (covered leather with a cloth) and gently rolled the area using a wallpaper roller. Worked out great, the foam bounced back mostly, and the leather looks perfect.
Old Oct 27, 2014 | 03:19 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by Beezvette
I
Old Oct 27, 2014 | 03:45 PM
bdharris68's Avatar
bdharris68
My car has 11k miles on it and the center console leather is loose/ has wrinkles. Not real happy about the quality. But I'm going to just have it recovered myself in higher quality material. What is bad is my truck of 100 k miles that I'm a lot more rough on has no wear areas of the console.
Old Oct 27, 2014 | 07:51 PM
Beezvette's Avatar
Beezvette
I think the foam below is very soft, and it seems to have a memory for indentations. Mine bounced back nicely. Try a little heat from the iron with a cotton cloth. No steam. I went over mine for a few minutes being sure not to get the leather too hot (lowest iron setting). Just about the time i figured it was not making a difference, i saw signs of improvement and in a few more minutes the indentations were gone. I think the roller helped out the foam also.
Old Oct 27, 2014 | 10:13 PM
bdharris68's Avatar
bdharris68
Thanks for sharing the tip.
I don't think we should be having to fix our cars interior before the second oil change. Especially how much we spent in these cars. After I take it to be repaired I will let you know what type of foam is under the leather.
Old Oct 28, 2014 | 08:13 PM
Beezvette's Avatar
Beezvette
Thanks i would be very interested. Please send me a PM so I do not miss your post. I agree it should not happen.
Old Nov 18, 2014 | 12:52 AM
bdharris68's Avatar
bdharris68
Went to an Apostery shop that does custom cars about this lid. They said the glue has pulled away from the lid. They suggested to go to dealer. So I did and have a new on it way.
Old Nov 18, 2014 | 07:15 AM
C7Joy's Avatar
C7Joy
Glad the heat solutions worked out for the OP. I was thinking along the lines of a hair drier but the iron indirectly applied was the key.
Old Nov 18, 2014 | 10:43 AM
foreverfuelie's Avatar
foreverfuelie
Just curious, Beezvette, 1Lt,2Lt,or 3Lt? Depends on who/what information we get, that the 1Lt & 2Lt's are not leather but a leather-like vinal. Only the 3Lt's are real leather, according to the "interior stylist" (Ron was his first name - missed the last) at the last Corvette Bash. Wondering if your problem is unique to one or the other console covering.
Old Nov 18, 2014 | 10:55 AM
Kracka's Avatar
Kracka
1LT and mine is doing it too. I plan to ask the dealership to replace it under warranty. Currently at 11k miles, but started noticing it around 9k.
Old Nov 18, 2014 | 11:22 AM
Glen e's Avatar
Glen e
3lt is plasticized leather too, they are all the same on the surface that you touch,,,
Old Nov 18, 2014 | 11:38 PM
bdharris68's Avatar
bdharris68
Mine is 1lt but Leather or not leather the interior of any car in my option should not turn to this especially in the first year.
To Question about center console lid
