Extra replacement key
Old Oct 27, 2014 | 12:18 PM
NavyBlue2's Avatar
NavyBlue2
Default Extra replacement key
If you lose a key, Does anyone knows how much Chevy dealer charges for a replacement key?
Sugg for other alt to purchasing a replacement key?
interesting article:
http://www.consumerreports.org/cro/m...less/index.htm
Old Oct 27, 2014 | 12:44 PM
jerryv's Avatar
jerryv
Here's my suggestion .. don't lose your key.
Old Oct 27, 2014 | 12:57 PM
ocjim's Avatar
ocjim
Purchased FOB plus key for $202.74, I think the the key only was $28 or & $29. Dealer had to order, Fob came programed and key was already cut
Old Oct 28, 2014 | 12:55 AM
NavyBlue2's Avatar
NavyBlue2
Anyone knows where we can buy FOB besides the dealer for less than $200?
Old Oct 28, 2014 | 01:24 AM
VETJAZZ's Avatar
VETJAZZ
You can find them on ebay.
http://www.ebay.com/itm/2014-Chevrolet-Corvette-Stingray-Coupe-Keyless-Remote-Key-Entry-Fob-GM-22779880-/251670828753?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a98c016d1&vxp=mtr
Old Oct 28, 2014 | 02:10 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Originally Posted by VETJAZZ
FYI, That's just the FOB, sans key
DESCRIPTION:
100% Genuine OEM Part.
2014 Chevrolet Corvette Stingray Coupe C7 Keyless Smart Remote
GM Part# 22779880
Insert Key blade is not included.(usually sold separately)
Old Oct 28, 2014 | 02:31 AM
Rad22's Avatar
Rad22
Here's the deal.
After losing my key (in an embarrassing fashion that we won't go into here), I learned the following. For the C7, GM took away the possibility of a dealer cutting your new metal key to fit inside the fob. The precut key must be ordered from GM directly, by your dealer after extensive verification of car ownership.
You certainly can order the fob itself from an outside source and you can even program it to your car without a lot of difficulty using a rather arcane and silly technique (incidentally, requiring the metal key inserted into the lock above the license plate). But, if you want the fob and the metallic key, it's going to cost you.
Old Oct 28, 2014 | 11:07 AM
NavyBlue2's Avatar
NavyBlue2
Originally Posted by Rad22
Here's the deal.
Thanks for your detail post.
My son in college had the same happened to his Ford. Will cost over $200 to get replacement FOB/Key from dealer. But he bought a 3rd replacement key online for less than $30, & it can only be programed if you still have the first 2 FOB/Key. He can't program his 3rd replacement without having orig 2 keys. Of course, 2 months after he bought 3rd key, he lost one orig key. He's in process of ordering another 4th replacement key... he says cheap insurance.
OK, so we buy the key directly from GM (thru dealer?) & can buy the FOB on our own?
Thanks,
Old Nov 11, 2014 | 06:49 PM
c5eddiem's Avatar
c5eddiem
Would you believe I lost one of my keys a few weeks ago. 95% chance it's somewhere in my house, but I can't find it! Tore the house upside down, room by room, no key!
I expect that I had it in my pocket and I said, "I 'd better put his away for now, somewhere where I won't lose it!".. and the proceeded to store it someplace nice and safe - so safe that I can't find it!
I can guarantee that I will find it right after I order a new one!
Ed
The good news: the C7 doesn't go out in our New England winters, so I really don't need the key until spring!
Old Nov 11, 2014 | 11:03 PM
tcotta411's Avatar
tcotta411
Default It happens to the best of us...
Good luck with finding it. It'll show up one of these days.
Good thing is you can always order one on eBay. It will likely be more expensive than what I'm asking, but much less expensive than the stealership.
Old Nov 11, 2014 | 11:13 PM
tcotta411's Avatar
tcotta411
Both fobs have been SOLD.
Thanks guys!
Old Nov 19, 2014 | 07:52 PM
CO Lightfoot's Avatar
CO Lightfoot
Cheap insurance: Get a bright-colored fob cover. You'll be less likely to lose it.
Also helps protect against drop-damage. Plus, it holds the key & fob together if the key is loosened.
Available from many sources, like this: http://www.thejacketstore.com/c6-c7-...e-cover-gmc75/
Note: This fit my C6 fob+key perfectly. Haven't tried it on a C7 but they're reportedly the same size: https://www.corvetteforum.com/forums...post1588117379
Old Nov 22, 2014 | 05:49 AM
Tracker's Avatar
Tracker
Here is a quick thought for GM.
If you have a button on your fob that blows the horn to find your car, maybe they should put a button in the car that makes the fob beep so you can find your fob!
Food for thought.
Old Nov 23, 2014 | 08:44 AM
tcotta411's Avatar
tcotta411
Make an offer on the new OEM C7 fob / transmitter I have for sale....the fob does not have remote start.
No reasonable offer will be refused.
These sell for $200+ at stealership.
Old Nov 29, 2014 | 02:56 PM
firefisher's Avatar
firefisher
Originally Posted by tcotta411
holiday bump
$40.00
Old Jan 10, 2015 | 08:06 AM
grandpawmoses's Avatar
grandpawmoses
Throwing in another thought. Do you have an extended warranty? Mine will pay for one replacement key/fob (it's not through GM).
Old Jan 10, 2015 | 02:18 PM
zbrett's Avatar
zbrett
I have these. Works fine with C7 fob.
To Extra replacement key
Old Jan 10, 2015 | 02:50 PM
KenHorse's Avatar
KenHorse
They also prevent pocket "fobbing" (having one of the buttons inadvertently pressed while in your pocket)
Which by the way, the FOB should NEVER leave your pocket when you're on the road....NEVER
Old Jan 10, 2015 | 03:14 PM
grandpawmoses
Looks like they don't work with convertibles. Am I missing something?
Old Jan 10, 2015 | 03:23 PM
Ernest_T's Avatar
Ernest_T
I bought a Camaro switchblade fob for $18 on e-bay and had it programmed. It was much cheaper than buying from GM. The fob might be available for the C7 too.
