ACS Splitter
Old Nov 26, 2014 | 05:14 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Originally Posted by ACS Composite
Hi Msg,
We take the lowest point of the front fascia and extend it parallel to the ground, definition of a splitter.... hence we don't lower the ride height, but do make the car longer by one inch. The notch is then added to help with drivability.
Driving a C7 Stingray Corvette up Driveways - YouTube
Thanks. This is a great video and really helps show the clearance.
I have a lowered C5 and I'm looking to add a C7 Z51 Stingray coupe and I've always liked the look of splitters. I parked my C5 next to a C7 last week at a local show and noticed that my C5 from bumper was lower than the C7 front bumper by about 2 inches.
Old Nov 26, 2014 | 08:28 PM
MSG C5's Avatar
MSG C5
Originally Posted by C7Joy
I think it lowers the clearance only the thickness of the material itself, maybe 1/8"? The front protrusion would be the main concern for me. The ACS video shows how to approach a driveway or other obstacle. But you know sooner or later you are bound to hear that distressing "Crunch"!
A friend of mine installed a splitter on a slammed C5Z. Before he installed it, he applied spray truck bedliner on the bottom of the splitter to help protect it against abrasions. He tells me it works well.
Old Nov 27, 2014 | 12:05 PM
op z's Avatar
op z
[QUOTE=ACS Composite;1588350767]Hi Msg,
Please post a copy of the installation instructions. Thank you in advance.
Old Nov 27, 2014 | 10:06 PM
MSG C5's Avatar
MSG C5
Hi Msg,
BTW - What front grill is that? I like it!
Old Nov 27, 2014 | 10:51 PM
E.T.D. Corvettes's Avatar
E.T.D. Corvettes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
It's the ACS grille. http://www.acscomposite.com/project/...tegory=9149724
Old Nov 27, 2014 | 10:55 PM
MSG C5's Avatar
MSG C5
Originally Posted by jagamajajaran
Thanks! A big "duh" moment for me as I completely missed it on their website.
Old Nov 27, 2014 | 11:16 PM
E.T.D. Corvettes
2015 C7 of the Year
No problem!
Old Nov 27, 2014 | 11:38 PM
killascrimp's Avatar
killascrimp
I have the front and side pkg. You do have to be careful with the front ..It looks great but I have damaged the front twice.A little sand paper and paint can fix the issues FYI
Old Nov 28, 2014 | 10:08 AM
MSG C5's Avatar
MSG C5
What type of finish is on the bottom, underside of the splitter? What finish did you choose?
Old Nov 28, 2014 | 12:06 PM
ACS Composite's Avatar
0ACS Composite
Former Vendor
All our parts are RTM molded, in simple terms, this means it is injected molded fiberglass. This gives us a smooth finish on either side of the part.
In addition we primed all our parts and undercoat the bottom surface, we use a bed liner type material to protect the panels from rock chips.
We also use continuous glass unlike most aftermarket parts are made with chopped strand mat and utilize high grade vynilester resins.... this is how we were able to meet GM's 7 year durability standard....
Old Nov 28, 2014 | 02:03 PM
MSG C5's Avatar
MSG C5
Thanks again for the information. So if you choose Carbon Flash as the finish, the bottom will still have the bed liner type material correct? Also, on the blue Stingray in the video, what is the clearance from the ground to the bottom of the splitter?
