Build Code
Old Mar 17, 2015 | 06:47 PM
mpuzach's Avatar
mpuzach
Originally Posted by dinows33
I Got this note Sat.
Here is your Final Corvette order SKXXBS that we went over with on the phone earlier today. Please re-confirm that the options are 100% correct. Your order will be at status 2000 (accepted by GM) on Tuesday and you won't be able to make any changes after that point. Please look line by line about your order. Now is the time to ask so we don’t have any mistakes on your Corvette order.
Can I assume although today is Tuesday it might be to early to check. Normally I am not anxious, but I was rejected at another dealership after holding my deposit for 4 weeks, so to say I am gun shy is an understatement. Now can I assume if it goes to 2000 I am, going to get the car ????????? Thanks A Million !!!
Hey Deano - your order IS currently at event code 2000; this means your car is definitely going to be built. You'll likely go to 3000 in the next day or two and you should get your TPW within the next couple of weeks. Congratulations!
Old Mar 17, 2015 | 07:16 PM
laborsmith's Avatar
laborsmith
It is to early to check with the CCS tracking thread because the overnight updates will not appear until tomorrow morning.
Tomorrow morning should answer your question and little can be done between now and then, so hang tight and sometime after nine check with either your dealer or CCS.
I have a good feeling but only time will tell.
Laborsmith
Old Mar 17, 2015 | 07:27 PM
DocGuy's Avatar
DocGuy
St. Jude Donor '15
No sir, it is not. You should have hit 2000 this AM. Go to https://chat.chevrolet.com/chevy/
and give them your order number, I am 99.9% sure they will tell you good news. That is if your dealer did have allocations that matched your constraints if you had any...
Old Mar 17, 2015 | 07:35 PM
dinows33's Avatar
dinows33
Well I guess mpuzach checked for me (thanks so much) Boy what a ride this has been
Thanks Everyone
Old Mar 17, 2015 | 07:38 PM
laborsmith's Avatar
laborsmith
Yep, 2000 means it will be built. GM does not accept order it unless it is certain it can be built.
For what it is worth, if it can not be built you will have an opportunity to roll over and if you so choose you are price protected.
Laborsmith
Old Mar 17, 2015 | 07:40 PM
mpuzach's Avatar
mpuzach
Thanks Everyone
I did indeed. You're on your way!
Old Mar 17, 2015 | 08:52 PM
bluman's Avatar
bluman
Originally Posted by laborsmith
2000 occurs Tuesday and appears in the general server the next morning. I believe the ordering dealer can see the 2000 status sometime on Tuesday - at the point in time the change occurs - but do not know for sure.
Laborsmith
Exactly what my dealer said to me !
