Interior Reading Lamps and Cargo Lamps - Bulb Replacement
Received 9,531 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
I intended on replacing the OEM white reading lamp bulbs with amber bulbs tonight, but discovered that these lights are actually LED lights that appear to be built directly into a circuit board. The first photo I have attached shows the reading lamp with the cover off and the second photo shows the light assembly with the circuit board on the back side of the assembly.
I had purchased the bulbs listed in this eBay auction: http://www.ebay.com/itm/231422268750?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT hoping I could use them with the reading lamps. Since I could not, I decided to install them in the rear cargo area instead.
The following photos show how the light bulbs install into the rear cargo area lamps. The lamp cover assembly is what the bulb plugs into and the lamp cover assembly then plugs into another connection point.
Update:
I posted a new thread with details on how to remove the rear view mirror, a-pillar trim, and reading lamps here: https://www.corvetteforum.com/forums...m-removal.html
In order to produce yellow light from the reading lamp LEDs, I got some yellow window tint and cut it into circles the size of a quarter. I even used a quarter as my pattern guide. I then applied the circle tint pieces to the lamp housings in order to cover the bulb area. In order to get to the desired yellow, I used three pieces on each side. This is the result:
Update:
Received 7,783 Likes
CORVETTE TODAY Host
St. Jude Donor'15
Oooo, I like the yellow, Jeremy!
I might do red for my reading lights. I've already done my Cargo/Trunk bulbs in white. I got mine from Diode Dynamics in St. Louis.
2015 C7 of the Year
Thanks! I have a "fix" for doing yellow on the reading lamps that I'm going to try and will post the results once I have a solution.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,403 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Will tel you what I did. Buy some plastic they sell to over cracked tail lights. Take cover off and cut a piece to cover the bulb. Peel off the protective cover and cover the bulb. The re-attach cover. I used red.
2015 C7 of the Year
2015 C7 of the Year
Update posted in original post with desired results.
