Yes, your garage is almost always warmer than winter outdoor conditions. I'd boost it up to match what could be 30 outdoors. For instance, my garage sits around 50 at 32 outside. If I know my car's going out and sitting somewhere, I adjust (and I do at the beginning of the season, just in case esp. for my DD) to the outside air, 32. As it goes down further (to 20) I adjust again with more air in the tires even as my garage stays between 45 and 50. Why? I'm not driving in my garage. As a tire engineer once said on the news, "I'd rather see someone with 2 pounds more air in their tires, than 1 below what they should have." A slight exaggeration both ways, but what he really is meaning is that someone with less air is more of a danger potentially (as temps get lower outside) than someone with a couple more.
I usually run my vehicles at higher pressures than recommended. Only negative is that too much air can affect traction slightly. Unless you really go overboard tire wear won't be affected. The upside is that when temperatures vary greatly from morning to afternoon, or day to day, you won't be getting TPMS faults. At least in the Vette you can check actual temps by tire, but in Ford and other co. products, you really don't know which tire, or how low they are.
Had my Flex give me a low tire reading on our trip back to IA at Christmas. Tires looked fine, so not wanting to dig out my pump or buy air... I just kept going. Turned out tires were like 1 lb below recommendation cold, which was due to outside temps dropping as we went North.
