A8 Question
Old Jan 5, 2015 | 06:23 PM
morganjo5's Avatar
morganjo5
Default A8 Question
I know the auto will downshift with the paddles and I assume the lower gear will have engine compression to slow (the same way a manual shifted to a lower gear uses engine compression to slow) My question is: when race/competition mode is selected and the paddles are not used, will the computer use engine compression to slow when braking hard for a corner - will the computer use engine compression with each lower gear during the braking? Thanks to anyone who knows.
Old Jan 6, 2015 | 08:34 AM
Ernest_T's Avatar
Ernest_T
I don't have mine yet, but on the test drive I didn't detect any compression braking caused by the transmission downshifting. I assume you are talking about what you feel with a manual when you shift to a lower gear at higher RPM. When you brake to slow down, and then hit the gas, it seemed like you could feel the transmission downshift as a result of the braking, but it just seemed to be in the right gear for the speed and engine RPM.
Old Jan 6, 2015 | 09:04 AM
abrimberry's Avatar
abrimberry
Cruise-In II Veteran
When the transmission has downshifted on its own when it thinks I'm driving "aggressively", it felt the same as manually downshifting. The lower gear / higher RPMs slowed the car a little. If that doesn't answer the question, please let me know. I can experiment, etc. Thanks.
To A8 Question
