Base vs Z51
:fu:
:fu:
Read more: http://gmauthority.com/blog/2013/02/...#ixzz4B2XUamUu
So Z51 wheels are forged but the base are ... ? Are there any weights available?
(BTW, gmauthority.com is almost tabloid. They have the LT1/L86 as being flex fuel)
I own a '15 Z51. I haven't noticed any excess brake dust, then again I have black wheels and wash my car regularly. But if a 1" difference in brakes size really does make that much difference in brake dust (and I have my doubts), you always have the option to switch to higher quality brake pads... no biggie. And of course larger brakes equate to better stopping performance. The braking performance on my car is outstanding. Of course if you live in a city, or get caught in stop & go traffic regularly, you will probably will see more brake dust. Then again, under these driving conditions, most cars will.
Since you've been reading these Z-51 vs Non-Z51 threads I'm sure you've noticed certain people will champion their decision (sometimes rigorously and argumentatively), one way or the other. You may have also noticed that some non-Z51 owners spend money on certain Z51 features such as the larger wheels & tires, sway bars, etc.
Also if the MRC is something you may want, you'll need to order the Z51 package. I enjoy the MRC features, and also like the idea of having the Electronic Differential and Differential Cooler.
I don't plan to track my C7 but do plan to sign up for the Ron Fellows course, and I really do enjoy having the Z51 goodies when I'm on twisty back roads. For me, it's nice to know the goodies are there if I want them, and if I wouldn't have bought a Z51 I probably would have always wondered how much better the car would have handled if I did.
As for comfort, my Z51 is plenty comfortable enough in the Tour Mode. Then again, if comfort was high on my priority list I would have bought a Caddy, not a Corvette.
I'm not trying to steer you one way or the other, just providing my opinions. Buy what suits you best, and whatever you buy I'm sure you'll enjoy the car.
FYI-I have a 2016 Stingray non-Z51 convertible with the Twilight Blue pkg. and I believe the MRC came with that pkg.
Just sayin'....
:fu:
Look at how massive a Lamborghini aventador yet it weighs 3500 pounds because of material used.
The forging process allows production of wheels that are lighter than cast wheels because they can be both thinner and stronger at the same time. Thus, it's possible and quite common for a larger forged wheel to be significantly lighter than a smaller cast one.
The Base C7 18-19 wheels are Cast Aluminum while the Z51 19-20 wheels are Forged Aluminum.
But there's other things to consider besides size and material.
The Design !
The design of Base wheels and Design of the Z51 wheels need to be considered along with material.
Cast wheels are going to be heavier than Forged wheels of the exact same size and design.
The Cast Aluminum is weaker so the wheels are made thicker in order to be strong enough.
The Z51 wheels may be bigger but being Forged they can be made thinner in certain areas and still be as strong or stronger, because of the Forged material.
Now depending on Design & Materials, the Bigger wheels can be the same weight, or Lighter, than smaller wheels.
Then.... there's the tires, which the wheels are useless without
The Base 18-19 tires have the Same overall diameter as the 19-20 tires.
So the Base tires have a larger side wall = More Rubber, more weight, added to the heavier Cast Aluminum, especially if they're Run Flats.
I have a set of Forged C6 Gumby 18-19 wheels with Mich A/S ZP tires on them and weighed them against my OEM Z51 C7 wheels/tires.
I forget now what the exact weights were but....
The 18-19 wheels/tires were Heavier
In this example, Design makes the difference with both wheels being Forged Aluminum.
I'm running 19-20 Forged Finspeed wheels with OEM Z51 Michelin tires.
Each Finspeed Front wheel/tire is 2.5 lbs lighter than the Front OEM Z51 wheel/tire.
Each Finspeed Rear wheel/tire is 3 lbs lighter than the Rear OEM Z51 wheel/tire.
YMMV
The Design !
YMMV
and we'd be around the same weight?
That $2,600 figure you mentioned for track prepping your car is a load of crap. For starters I just keep 15w50 in my vehicle at all times, but it isn't my daily and I live in a hot climate, so long as the car is warmed up it isn't an issue. Tadge mentions that you shouldn't daily with 15w50 because the added levels of phosphorus can cause pre mature cat failure (we're talking real long term here not just a couple years). Further more there is not need to take the cooling rings on and off, in my opinion keep them off or keep them on. I've kept mine on for the past five months, it's not going to hurt anything. A track alignment isn't needed if you're only going to track your car a couple times a year. However if you're going to do it more than that, then yeah you'll at least want some negative camber to minimize tire wear. In terms of insurance, that's up to you if you want to get a third party insurance, no matter what you drive or what "normal" insurance company you have, you're going to need a third party insurance, IF you want the car covered at the track.
However, IF you're going to do a decent amount of road course events at the track the Z51 package is WELL worth the money. The important things you're getting here are the fluid coolers, eDiff, and dry sump oil system, some nice pluses is bigger brakes and slightly better aero (but probably something a novice would never notice). I've ridden in a base C7, while it is much improved over the C6, my C7 Z51 is WORLDS better on the track than a base model. You're getting a better suspension set up with the shocks and sway bars. Another thing to consider is if you want to really get into modifying your suspension, get it without mag ride so you can swap to a very good coil over set up. That's what I did. I came from a '13 ZL1 which had GMs third gen mag ride, while being absolutely awesome on the street it was only OK on the road course. the PTM system was great when I was a novice but once you become experienced the mag ride isn't the best set up. It's a compromise between road course and street.
In summary definitely get the Z51 if you're going to road course it more than 1-2 times a year, it would cost you WAY more money to do a third party dry sump and the eDiff you couldn't transfer over.
Glad to see someone that doesn't take some things on this forum so seriously.
BTW I think you'r wheels look great! Then I just got a Li-iron battery for it, that was another ~10# weight lost for $150
That's a lot easier than dieting...
