My Curb Alert install in a Z06 Grille
unplug speaker and plug this in, or Y split it; it will trigger both speaker and light:
Followed managerman's install exactly, and it works perfectly on my Z!
the current just lights a light, not actuates a speaker.....don't overthink this...just hook the speaker output to an led light. This has been done with the approval of the inventor of this device, He has become a friend of mine...
I'm with you on the control box - mine is under the glove box next to the speaker and will stay there, too hot in that engine compartment if you have a choice IMO. If you feel like it I would like to see a photo of your install of the sensor. Which mount did you use?
St. Jude Donor '06-'07-'10, '15. '22-'23
My Sensor Installation
Thanks again for all the info guys. This has been very helpful. I looked at the various options and decided on a slightly different mounting. I used the short bracket that was installed on the sensor when it came. However instead of using the side where the VHB tape was already installed, I removed that and decided to use new tape on the other side. Two reasons for this. 1) I thought that "hanging" the sensor on the slat instead of mounting from the underside would make for a little better mounting - that way the sensor pulling downward only makes the contact with the grille better, and 2) Mounting this way gave me a little more adjustment of the sensor up and down. Here are a few pix so you can see what I mean. I will be installing the grille later today and hopefully getting the curb alert recalibrated and good to go!
Awesome! Looks great!! Good luck on the Grill install!
-M
Hi Glen e,
Can you point me in the right direction to find a red led with the right connector? Also where/how did you mount it?
#34
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
#36
Thanks for the very detailed post, much appreciated. I'm just thinking that GM could/should have included this as an option on a car that can top the $100K (mine did). Some of us who are mechanically challenged (me again) could just factory order options like this. Just a thought, enjoyed you post though.
#37
Received 1,575 Likes
2023 C8 of the Year Finalist - Modified
2022 C8 of the Year Finalist - Unmodified
2021 Corvette of the Year - Unmodified
Winner 2020 C7 of the Year - Unmodified
I did not like how the sensor looked when pushed to the front of the grill. I think it takes away from the clean look. I took some black gutter screen and zip tied it to the grill. on the diagonal it matches the screening on the rear of the car. By cutting slots in the screen you can fold back tabs to hold the sensor recessed back from the front of the grill. If you fold the slats back narrower than the sensor it will hold it tight while you test it for a proper angle. When I got the angle set I carefully jb welded and tapped it in place. I did this before the lower portion of the car was reassembled. Be careful not to bump the senor until dry. You can't see the sensor unless you bend down pretty low to see it. Some may not like gluing it in place. you may be able to create a different mounting solution.
#38
This is a great "How To" thread. Since it is so easy to bring a wire inside to the cabin, I'm going to bring in the power lead and tap the lighter socket in the console. This will give me a switched source of power. Since I hook up to a battery maintainer at night, I don't want the sensor talking to me as I walk past the front of the car.
I have this thread bookmarked for my install.
Elmer
Elmer
