The higher the altitude the lower the lower the Octane needed.
Octane is the ability of a fuel to resist knock, and high-compression engines tend to knock more. The obverse of that is that lower-compression engines can run on lower-octane gas. Air is thinner the higher above sea level you go. Less air going into the cylinders means less pressure at top dead center when things go bang. It's a lot like lowering the compression ratio in the engine, reducing the need for high octane. Cars will run just fine on lower-octane fuel when they're well above sea level.
For each 1,000 feed one's compression ratio drops approximately 3%. Here in Utah we are at 5,000 ish feet. Thus our compression rations are 85% of what sea level C-7s run.
I've used middle grade gas (87-89 Octane here) on high performance engines at our higher altitudes for decades and NEVER had any problems with knocking or performance.
My $.02
PS: Regular Fuel here is 85 Octane.
This always puzzles me. you drive a 60K+ car. Why in the world would you want to skimp on the gas? as mentioned earlier, you're typically looking at a $2-$3 difference per tank. If you are really hard up for the couple of bucks, you need to re-evaluate your decision to buy an expensive car. If you just don't want to give the car the best fuel you can give it (which is what the mfg recommends anyway) then once again, you need to re-evaluate your decision to buy this car. lol
Couldn't have said it better. This discussion happens on every performance car site I've been on, and I still have yet to understand it. I'm still trying to find a way to understand the psyche of such posters so I can make money off of their poor choices!
And I understand the exception for high altitudes...
It amazes how many people do not answer the question. Some of you are just down right rude!
My question has NOTHING to do with the cost of the fuel, or my ability to pay for it.
I am asking whether after a year of real world use, has anyone had trouble running regular fuel?
New 2015 on the way, and if I get caught running a tank of regular fuel because my local station runs out - has this caused anyone any trouble?
Using lower grade fuel on a premium required car can cause engine knock, which can be harmful to your engine. Modern cars have sensors that can adjust ignition timing to help mitigate this though. The higher octane fuel you use, the more resistant to auto-ignition (or knock) it is. It will function on regular, but the sensor will be changing the ignition timing to something that's less than optimal. Because of this, you'll take a hit in torque and an mpg hit. Should the sensor fail, you'll likely hear a "knocking" or "pinging" noise. If that should happen, I would advise against driving it at the limit (just to be extra cautious) until you get some more premium in the tank.
I wouldn't make a habit of it but your car won't detonate. Hope that helps.
Golly...I don't know what to do at the gas pump anymore!
I read the "covering our *** manual"....I mean "owners manual" regarding octane ratings.........just remember when you see the words, "can be used", "could be damaged", "may occur & may void" and the holy grail, "recommended"....just reach up and scratch your head, hope you don't go deaf so you can hear strange fuel related noises at 5 thousand RPM so sum hungry mechanic on the forum can make a boat payment on you fixing the engine cuzz he "knows" these words are clear, concise, irrevocable and final! Just relax, your engine isn't going to care and the GM lawyers can sleep at nite.
When the New Stingray Engine was being introduced, one of the things GM touted, "the new Corvette can run on regular unleaded fuel although premium fuel will be recommended".
-- The engine has an 11.5:1 compression ratio. That higher than the current engine's 10.7:1 compression ratio. Despite the higher ratio, the new Corvette can run on regular unleaded fuel although premium fuel will be recommended.
when the new stingray engine was being introduced, one of the things gm touted, "the new corvette can run on regular unleaded fuel although premium fuel will be recommended".
this is exactly why i asked the original question of anyone that has been running the new c7 for a year whether regular fuel has damaged the motor.
Seriously doubt any one has had a 2014 long enough for 87 octane to damage the motor enough to know. I am sure some have run nothing but 87 in their Stingray.
Find it hard to believe some one would spend over 50K on a car, where it recommends 91 or higher and not use it, even if you can use 87.
Both of My wife's Mercedes ML SUV & daughter's 3 Series cars with 6 cylinders "recommends" mid grade fuel with 91 octane.
Both of them has been using 87 octane reg gas for over 3 yrs now, with no problems with performance nor gas mileage.
But I'll stick with premium gas my C7 since I drive her a lot more agressively....
So you spend a min of $55k new, probably closer to $70k on a brand new sports car and you want to put regular gas in it? Especially these days with the prices so low. $.30 a gallon isn't much so give up a fast food lunch per week and you'll be ok. It will be better for you and the car anyway.
In Utah 85 octane is regular so I don't think you want to use that if you every passed by here.
Now that the C7 has been out in the real world for over a year.......
What's the verdict about running premium versus regular fuel?
Does the engine really perform better?
Will it hurt the car if you don't run premium gas?
Since I don't like running my C-7 below 1/2 tank, I put in 1/2 tank of 93, and on the next fill, I put in 1/2 tank of 87.. When mixed u have an octane rating of 90 average... This engine can only utilize with full advance 91 octane... Have never experienced any pinging even going up hill and on throttle ... Always park mine w/full tank as its not a daily driver.. Do this same procedure on all my high performance bikes and boat...
Your math is questionable. Looks to me like on the times you fill with 93, the resulting tank will be 91, while on the times you fill with 87, your tank will be 89. So you are constantly alternating between 89 and 91 in your tank. The knock sensors will theoretically cover you at 89, but just barely, and there’s always at least a bit of a lag as the knock sensor “catches up” with what’s really in the tank. If you doubt my math, consider that half at 89 plus half at 93 equals 91, and then on the next fillup, half at 91 plus half at 87 equals 89. Yes, over time, it averages out to be 90, but it gets to that average of 90 by tank to tank switching back and forth between 89 and 91.
Yes, it probably is just a little under 90 octane, but doubt the engine can even tell the difference unless tracking the car..
Kind of go by what the knock vibration sensors are telling me.. My other car is a Shelby GT 350 which recommends 91 octane as well, but have never heard the marbles in the engine sounds in it either under hard accel..
A full tank of gas will cost you about $5 more for premium. If you are cruising all day then you probably won't have an issue with the regular gas and can probably fill it up if needed. However, I doubt you will every run into a problem of not being able to find 91 octane gas somewhere before your engine flames out. However the Corvette likes to climb hills at lower RPM (if you have an automatic). This puts stress on the motor somewhat. My intention was never to flame the OP but there are many other places in life where you can save about $5 a week.
All of our gas is like garbage anyway compared to German gas. 91 AKI is 95 RON in the rest of the world, that is regular gas in Germany with 100 RON being premium.
Decision to mix the fuels isn't as much about saving some money on the fuel, but simply wasting it on a product that doesn't give any additional benefit in mpg or driveability, or that that matter performance...
In areas where 93 isn't prevalent, this blending doesn't work very well.. I broke in my 15 A8 Z-51 in on strictly 93 premium for about 1500 miles..
My mpg and drivability is identical as when I switched to the mixture..
The spark advance in the ECM doesnt do anything better with 93 than 91, and from 91 to 90 octane probably isn't even recognizable in the spark advance system. I thought I would see even a small amount of mpg loss, but its identical.. I drive the same route 3 days a week, and about the same speeds... Even the plugs look the same. With no sign of preignition, or sounds of it. I don't track my car, but do jump on it once in a while when an SS Camaro starts barking at a light, but all in all, it runs fine with the mix. I do run the recommended amount of Marvel Oil in my fuel since a kid, and it has additional benzene in it which is an octane improver.. Not much though, about 8 ounces per tankful.
The difference between AKI and RON is seldom as low as 4. More typical range is 5-6. Most European premium is 98RON, which is essentially the same as our 93 AKI premium. Some places in Europe do sell 100 RON ultra premium, and that would be in the range of 94-95 on the AKI scale. But before you complain too much about that, or about California’s 91 AKI premium, you should understand at least a bit about the whys.
US gasoline on the whole is a bit lower octane because we make a much higher fraction of our fuel into gasoline, with much less of it going to diesel. A detailed discussion of why that affects octane would be a very long post, boring most to tears with technical jargon. But a short, layman’s version is that if you are trying to maximize gasoline yield, you have to keep all the gasoline range components in gasoline, you can’t afford to use some of the lower octane ones for other products. The reason for California being lower than the rest of the US is California state air pollution regulations. They very heavily restrict olefins in gasoline, and olefins are considerably higher octane than their corresponding saturates. So these things are not big conspiracies and do not represent selling “garbage”. It’s simply a case of situations being different in different places.
Agree there is little or no penalty dropping from 93 to 91. But as I mentioned earlier, your strategy does not result in a further drop from 91 to 90, it is from 91 to 89. Every other tank, you are running what amounts to straight mid grade. That’s not disastrously bad. The knock sensors should catch it. But it is taking at least a bit of a chance. You may well get by with it, but I doubt that many would want to chance it.
