California Registration Issues
"Monitors Not Ready: Oxygen Sensor and Evaporative System.
Local dealer says.. "drive the car and problem will resolve it's self".
Now have 200 miles on car....issue unresolved.
To perform an OBDII Driving cycle do the following (not everything is applicable to all cars):
1. Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 50°C (122°F) and within 6°C (11°F) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
2. Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
3. Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
4. Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
5. Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
6. Accelerate. Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
7. Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
8. Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
No smog check, received plates 3 weeks later with registration sticker. Received personal plates just yesterday and visited the DMV to pick them up, no mention of a smog check.
Not sure how else I can convince you that your statement is incorrect.
Calif. DMV requires SMOG certificate to register the car....car failed test.
Anyone else have similar experience...suggestions.
Its not that I don't enjoy driving my car....its just a hassle and my 20 days to register the car are are up.
1. There is a "drive cycle" that you can do that will allow the readiness motors to complete. Sometimes it will take several "drive cycles" to complete the readiness monitors. Do a search "drive cycle to pass emissions".
2. Buy an inexpensive code reader that will tell you which readiness monitors are complete or incomplete. Bring the car in for a smog test when you have completed all but 1 readiness monitor. Remember, in CA you are allow to have 1 incomplete readiness monitor.
3. Drive the car around for a 100 - 200 miles and hope it will pass.
I bought mine from a Oregon dealer with CA emissions and had it delivered to my house. DMV in Roseville still made me get it smogged. I put 500mi on it, then took it back to the smog check for a 3rd time before the monitor was activated.
The manual does make reference to issue. Recommends several days of everyday driving to activate the monitor.
If you purchase your car in Ca then yes no smog required as you mentioned. But the op bought his car out of state and had it trucked from another dealer thus he will have a vin verification, emissions sticker inspection, smog certification and then pay CA taxes even though it was bought out of state. There are no exemptions to this other than if you paid some sales tax to the other state, you will pay the difference to Ca.
Not doubting your word or others, but what year did this occur? Up until relatively recently a car with the CA sticker on (which was still a 50 state legal car, but WITH the sticker) did not need a smogging. So, are you saying a car from a CA dealer ordered for CA with the CA sticker still has to be smogged before it can legally go out on the road?
Once again I can provide positive proof, as my first C6 was a 2005 I bought in early 2006 with 4500 miles on it from a guy in Michigan. Less then 1 year, less then 7500 miles, and his car was not a CA emissions car as it was sold in Michigan, but was a 50 state car. Smogged it, took it to DMV for inspection, they noted the 50 state and current smog, and sent me on my way.
He WILL need a smog cert and if is not a 50 state/Calif approved vehicle, actually cannot be registered here.
I just picked up a 2015 Suburban in Oklahoma and it is 50 state approved and DMV DID require a smog and vehicle inspection at the DMV when I registered it.
There are several posts on here with CA registration discussions and one has a well put together list of what is needed to accomplish the task.
