Question regarding LSD
Old Mar 3, 2015 | 11:30 AM
c7v's Avatar
c7v
Default Question regarding LSD
Please help. I am the owner of a c7 with a regular LSD (non-z51 car). I was parked with both of the wheels on snow/ice. Leaving the parking spot, my right wheel was slipping and could not grab any traction, i assumed since i have a LSD, that the power would just transfer to the left wheel and the car would move, but it didn't. The right wheel kept spinning and the left would not move. I remember when i had a solstice GXP with a limited slip and one wheel would never slip without the other turning. Is it possible that there was too much weight transfer over the left wheel and thats why it wouldn't turn or should i start worrying (based on some new threads) that my differential seal couldn't handle the weather and leaked out all the fluid. I appreciate any feedback.
Old Mar 3, 2015 | 11:44 AM
10mm_'s Avatar
10mm_
St. Jude Donor '15
That's where the "slip" in limited slip differential comes from. It's not a locker, which would deliver equal power to both wheels all the time. The differential has a series of clutch plates in it to allow one wheel to spin faster than the other (like when you are turning) and if you are on a very slippery surface like mud or ice you can see a big differential in wheel speeds. Many times even cars doing a burnout at the track will only spin one tire even if the differential is working properly.
Don't worry.
Old Mar 3, 2015 | 11:52 AM
millpond's Avatar
millpond
c7v's Avatar
c7v
Don't worry.
Understood, thank you. It was just strange to see that the left wheel was not rotating at all.
Old Mar 3, 2015 | 11:55 AM
c7v's Avatar
c7v
Originally Posted by millpond
Thank you for that, still laughing. That was my facial expression yesterday.
Old Mar 3, 2015 | 12:11 PM
Crabbers's Avatar
Crabbers
Old Mar 3, 2015 | 12:37 PM
stevebz06's Avatar
stevebz06
I'm not so sure that it's working the way it should. LSD's do fail. You could jack up one rear wheel with the car in neutral (make sure you chock enough of the wheels to keep it from rolling, preferably on level ground) and try to turn the raised wheel by hand. After a small amount of rotation, it should give you a lot of resistance and prevent you from rotating the wheel.
Is it possible that the wheel not rotating was frozen to the surface?
Old Mar 3, 2015 | 12:46 PM
c7v's Avatar
c7v
Thank you for the feedback. I will try that at the end of the week, the car was scheduled to be raised on a lift to power-wash the bottom of the car, once up there, i will do as you said. Its impossible that it was frozen because i noticed this a few seconds after pulling into a parking spot and then trying to inch forward. The car would not budge and the left wheel NEVER rotated, i purposely held down the gas gently but enough power to have the rear right spin non stop. I also tried turning traction and all other controls on and off, including cycling through the modes.
Old Mar 3, 2015 | 01:02 PM
olympic's Avatar
olympic
Lucy in the Sky with Diamonds is missing??
Old Mar 3, 2015 | 07:58 PM
c7v's Avatar
c7v
Anybody?
Old Mar 3, 2015 | 09:41 PM
10mm_'s Avatar
10mm_
St. Jude Donor '15
Originally Posted by c7v
Anybody?
I already answered your question. You're concerned over nothing, it's completely normal. Go enjoy your car.
Old Mar 3, 2015 | 10:54 PM
c7v's Avatar
c7v
So it's possible that there are times when the differential would not transfer power to the wheel with grip? I was under the impression that although there might be some differences in rotational speed, I didn't expect it to just not transfer any power at all, the other wheel did not move. Appreciate your help.
Old Mar 3, 2015 | 11:27 PM
z51vett's Avatar
z51vett
When I saw the title to the post this was the first thing that popped into my mind that cat is killer.
z51vett
Doug
Old Mar 4, 2015 | 12:02 AM
Crossed Flags Fan's Avatar
Crossed Flags Fan
Lysergic acid diethylamide is a psychedelic drug of the ergoline family, well known for its psychological effects, which can include altered thinking processes, closed- and open-eye visuals, synesthesia, an altered sense of time and spiritual experiences, as well as for its key role in 1960s counterculture. It is used mainly as an entheogen and recreational drug. LSD is non-addictive, and is not known to cause brain damage.[Haaaaa!] However, acute adverse psychiatric reactions such as anxiety, paranoia, and delusions are possible - such as seeing some wheels spinning while others are not.
You may experience strange colors such as Torch Me Red, Laguna Beach Blue, Shark Tank Gray, Cyrstaline Red, etc.
"Man what long strange trip its been..."
Old Mar 4, 2015 | 09:08 AM
10mm_'s Avatar
10mm_
St. Jude Donor '15
Yes it is possible. If you feel so inclined check for leaks, gear oil doesn't dry so if there was a leak you will see where it ran down.
Old Mar 4, 2015 | 10:07 AM
Woodson's Avatar
Woodson
Of course Jim Morrisson would post that
Old Mar 4, 2015 | 10:32 AM
Larry/car's Avatar
Larry/car
I thought that we had what used to be called; Positraction = power would transfer from the wheel that slipped to the wheel with grip. This would happen automatically, driver would never know it happened. Evidently c7v's car didn't accomplish this?
To Question regarding LSD
Old Mar 4, 2015 | 10:35 AM
stevebz06's Avatar
stevebz06
I don't quite understand why the assumption is that it's working normally. This is one of the situations that the limited slip is supposed to prevent.
If the clutch pack is allowing that much slip, then you might as well
be driving a car with an open differential. With that situation, you'll have all kinds of trouble getting power to the ground on launch and corner exit.
I would make them prove to me that it's working correctly.
Old Mar 4, 2015 | 10:37 AM
stevebz06's Avatar
stevebz06
If you do go in with a warranty question, they will probably try to convince you that
any thing you come in with is normal. Do some research ahead of time and be persistent.
Old Mar 4, 2015 | 12:03 PM
millpond's Avatar
millpond
From the grave. The Lizard King
