No M7 temps?
Old Mar 5, 2015 | 06:47 PM
11B250's Avatar
11B250
Default No M7 temps?
I thought all C7s had transmission temp gauges/sensors... I'm surprised it's not on my screen. am I just having problems getting to it, or is this only for A8 cars? or Z51 maybe??
Old Mar 5, 2015 | 07:04 PM
Bill B 1's Avatar
Bill B 1
I'm pretty sure its there but you will have to configure your cluster to show it. It's been awhile since I messed with it so I cant say for sure how.
Old Mar 5, 2015 | 07:11 PM
11B250's Avatar
11B250
I went through them and keep going in a circle. Don't see it... very weird
Any help anyone?
Old Mar 5, 2015 | 07:38 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
You can configure the trans temp to display in the drivers info center, using the steering wheel arrow / select keys.
Old Mar 5, 2015 | 08:00 PM
gmccreary's Avatar
gmccreary
The trans temp can be displayed in the center by selecting the Perf menu
Old Mar 5, 2015 | 08:09 PM
11B250's Avatar
11B250
it's not there!!!!! this is driving me nuts.... is it only z51 cars? Mine is non z51
Old Mar 5, 2015 | 08:19 PM
TNSQUIRE's Avatar
TNSQUIRE
I believe that option is only on Z51
Old Mar 5, 2015 | 08:46 PM
romaja's Avatar
romaja
I believe the are called Pocket Gauges.
Page 5-41 of the owners manual.
Old Mar 5, 2015 | 08:47 PM
RonC7's Avatar
RonC7
I can display M7 temp in Sport mode display as a pocket gauge. It also shows up in Track mode display on the performance multi gauge display.
See sticky on the DIC Menu:
Ron
https://www.corvetteforum.com/forums...chy-chart.html
Old Mar 5, 2015 | 09:04 PM
11B250's Avatar
11B250
Ron
Looks like you have a Z51 as well
It must be, because I don't have it. I guess GM didn't wanns spend the extra 5 bucks for the sensor lol... perhaps it's attached to a line on the transmission cooler.
oh well...
Old Mar 5, 2015 | 09:15 PM
Sallye M's Avatar
Sallye M
22 Hypersonic Grey HTC
You can set a pocket gauge to show the transmission temp on the DIC in the Performance menu. It's available on my A6 non-Z51.
Old Mar 5, 2015 | 09:33 PM
11B250's Avatar
11B250
i believe only non z51 m7s don't have it...
can someone confirm,??
Old Mar 5, 2015 | 09:41 PM
Sallye M's Avatar
Sallye M
That's a picture of my A6 non-Z51 DIC. The left pocket gauge shows transmission temp.
That's the only choice I get to measure anything for the transmission.
Old Mar 5, 2015 | 09:58 PM
LrgZ51's Avatar
LrgZ51
No external trans fluid oil cooler, no trans fluid temp pocket gauge.
Old Mar 5, 2015 | 11:24 PM
11B250's Avatar
11B250
Attachment 47868862
That's a picture of my A6 non-Z51 DIC. The left pocket gauge shows transmission fluid temp - not transmission temp.
automatics have always had them, dating back to C5
Old Mar 5, 2015 | 11:25 PM
11B250's Avatar
11B250
yeah it's a real bummer... I wonder why GM skipped out on it... it's always good to have. doubt it's an expensive sensor
Old Mar 5, 2015 | 11:34 PM
Joy c7's Avatar
Joy c7
Learn something every day. sorry about the trans temp.
To No M7 temps?
Old Mar 6, 2015 | 03:00 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
I have an M7 Z51 and just put my Trans Temp on the left pocket gauge today! Switched from Battery Voltage. It hit 80 yesterday so thought it was time! It will 45 tomorrow, didn’t last!
Used the steering wheel controls, hit the left arrow, and scrolled to the bottom to Settings. Found pocket gauges and scrolled thru Oil Pressure, Oil Temperature, Battery Voltage, and Transmission Temperature. Have Oil Temp on the right.
Old Mar 6, 2015 | 08:13 AM
11B250's Avatar
11B250
yes, but you have z51. looking for non z51 people to chime in lol
Old Mar 6, 2015 | 09:51 AM
jedblanks's Avatar
jedblanks
I have non -Z51 and I haven't seen it. That being said, I'm not sure why it would be necessary on a M7.
Those with trans gauges on Z51 M7s, what are they running?
Do the new M7s use 90 wt gear oil or Dexron III/IV? I know that in my c5 I switched from Dex III to Royal Purple Synchromax and it took longer to warm up for smooth shifting. I would think gear oil would not be as affected by heat. At the time I was told that ATF was used so that cold shifting would be more acceptable in northern states.
I would think any heat building would be transmitted from the differential (which is directly behind trans).
