Wheel Locks
Old Mar 12, 2015 | 12:46 AM
sl33p3r15's Avatar
sl33p3r15
Originally Posted by mendeldl
My C7 is coming with Black Machined Faced Aluminum wheels. Does anyone know if the lugs are black or are they chrome?
They will most likely be chrome.
Old Mar 12, 2015 | 12:50 AM
NavyBlue2's Avatar
NavyBlue2
McGard works great!
Old Mar 12, 2015 | 08:43 AM
nmvettec7's Avatar
nmvettec7
Amazon sells McGard wheels locks in BLACK.
http://www.amazon.com/s/ref=nb_sb_no...0locks%20black
Old Mar 12, 2015 | 09:21 AM
Harry2's Avatar
Harry2
I have used the same set of GM/McGard wheel locks for three C6's and my current '14 C7. Wheel on the floor, remove the OEM lug nut and replace with the McGard, easy and simple task.
Old Mar 14, 2015 | 09:24 PM
meyerweb's Avatar
meyerweb
Originally Posted by vetorama
Used the link and amazon said will not fit 2014 Corvette.
They match the specs of the C7 lug nuts. I see a lot of items on Amazon say they don't fit the C7. I think Amazon's database is out of data.
I'll know for sure in a couple of months. I have those on another car now, so when my 'vette comes in I'll pull one off and see if it works properly.
Old Mar 16, 2015 | 09:57 AM
meyerweb's Avatar
meyerweb
Got the word from McGard on the right wheel locks for the C7:
Hello again Bob. We have 2 part numbers that will work for your Corvette, depending on which color you would like Part 24137 is Chrome and Part 24026 is Black. Either will work for your vehicle and both are available on our website. Thank you again for your patience. If you have any other questions, please feel free to ask!
The chrome ones are $20 on Amazon. I didn't look for the black ones.
Old Mar 16, 2015 | 09:59 AM
Originally Posted by Rave
Consider it this way. If you remove one lug nut and the wheel moves on the other 4 lugs (at all), the other four lugs weren't tight. My thought is, you shouldn't have any issue removing and replacing one lug.
This. You'll be fine doing it the way you propose.
